benni Options
benni
#1 Posted : 31 December 2018 11:28:19
Rank: Amateur Level 1
Thanks all for the help so far...those pointing out my spoking mistake on the last row, and Roy for the offer of decals (Unfortunately I can't afford them at the moment) so I am going with Photoshop and printing to my inkjet printer.
The build continues: Next the engine block. No real problems here.
The block with the carburetors and air cleaner attached.
[O:\digipics_nikon\subject\benni\models\jag models\E-type jag\build post\engine block][/9bp_IMG_20180905_141625s.jpg]
Then fitting the coil and leads:
[O:\digipics_nikon\subject\benni\models\jag models\E-type jag\build post\engine block][/11bp_IMG_20181010_104157s.jpg]
And a pic showing the "rust" on the manifold:
[O:\digipics_nikon\subject\benni\models\jag models\E-type jag\build post\engine block][/17a2bp_IMG_20181123_175940s.jpg]
Back to the other side to show the detailing on the distributor:
[O:\digipics_nikon\subject\benni\models\jag models\E-type jag\build post\engine block][/17a2cbp_IMG_20181215_125800s.jpg]
And finally a top view showing the Lucas plate on the coil:
[O:\digipics_nikon\subject\benni\models\jag models\E-type jag\build post\engine block][/17a3bp_IMG_20181228_091328rs.jpg]
benni attached the following image(s):
Built: HMS Victory
#2 Posted : 31 December 2018 14:51:18
Taking shape nicely BenniBigGrin good work.
This page was generated in 0.100 seconds.
