R2-D2 Voice/Patrol Problem Options
Highwayman
#1 Posted : 31 December 2018 18:33:34
Rank: Beginner Level 1
I am having problems with the voice control - very randomly does it activate on the Hey R2 or Good morning commands and then all other commends are very hit ad miss - it doesn't seem to be able to hear or discern the commands very well - anyone else having this problem? Is the re a fault with the Mic?
#2 Posted : 31 December 2018 18:52:55
Back ground noise can sometimes effect R2 and try to be clear and presice in what you say.
Highwayman
#3 Posted : 31 December 2018 19:04:56
I have tried it in so may ways now but no reliability. Even tried an American accent!
Highwayman
#4 Posted : 31 December 2018 19:08:32
My patrol mode also has some issues - keeps bumping into things. Additionally, the front foot micro-switch does not stop him as it does not sit further forward than his body - could there be an issue with the ultrasound sensors?
#5 Posted : 31 December 2018 19:36:42
You should check all the connections to make sure they are fully seated and none have worked loose and all are connected the correct way round. Also check and ensure that none of the pins in the plugs/sockets are bent or damaged.
Can you also post up a link to the batteries you have purchased.
Highwayman
#6 Posted : 31 December 2018 20:15:05
Thanks Alan - I have checked all connections, including those from the shoulder sensors and can't see anything amiss. is there some other way of testing the equipment is functioning?
Ref the batteries, I purchased these from 18650.uk - Samsung made - 30Q
#7 Posted : 02 January 2019 23:36:30
Can you check all the cables have been labelled up correctly. During assembly did all the sensor tests and checks work as they should?
Highwayman
#8 Posted : 05 January 2019 20:05:23
All tests on the sensors Worked fine on the build. After playing around and doing checks over the last few days, I can’t find any issues with pins, connections, labelling or anything else so my only assumption is the PCU. Are others having similar issues with the autonomous patrol mode and Voice controls?
#9 Posted : 05 January 2019 21:40:59
Contact customer services and request a replacement MCU..
Highwayman
#10 Posted : 06 January 2019 13:25:46
OK, thanks - the only sensor that does seem to work is the front foot edge sensor
This page was generated in 1.338 seconds.
