R2D2 wont work Options
Koah
#1 Posted : 02 January 2019 11:22:42
Hi i just completed R2D2 and he wont work. Do i have the right batteries?
https://www.ebay.co.uk/i...sid=p2057872.m2749.l2649
#2 Posted : 02 January 2019 11:50:50
There are several batteries available in the link you’ve provided, but it’s looks like the batteries you’ve purchased are protected ones, they should be Unprotected.
The spec you need:
Type: 18650 lithium-ion batteries
3.7v (or 3.6v) 'nominal'
Button-top
At least 3 Amps capacity discharge
At least 2000mAh capacity - (recommend 2600-2800mAh)
"Unprotected" battery type
Some members have purchased this battery which meets the spec: https://18650.uk/product/samsung-30q-button-top/
This page was generated in 0.171 seconds.
