R2 complete and 99.9% working! Options
James H
#1 Posted : 02 January 2019 16:25:40
All done!
My last three issues finally rocked up today so spent some careful time working though them. Startup sequence was perfect, and I eventually got R2 paired for direct connection, thanks to Semaj!
All features and functions work perfectly via buttons and app, with hologram/sound excellent, and arms and sabre doing their thing too. Test driven it for a while and had some real fun. My only issue is the left left motor makes a grinding noise when R2 is turning etc. Does the same if I move my hand, so I'll need to order a replacement motor, but apart from that........R2 is a total success!!
Thanks for the staff and members posting up their suggestions and stuff and I'm sure reading those made me more careful with my own project!
All the best for 2019!
Oh....for info, the batteries I use on my R2 are these from 18650.uk, in case you are still wondering what to buy:
https://18650.uk/product/samsung-30q-button-top/
#2 Posted : 02 January 2019 19:44:04
BigGrin Good to see another R2 up and runningCool
James H
#3 Posted : 02 January 2019 20:27:01
I'll do a short video tomorrow. Just ignore the farting sound he makes with the motor gearing.
#4 Posted : 02 January 2019 20:31:43
Great to hear you are all up and running. ThumpUp
DC-Zol.
#5 Posted : 02 January 2019 21:17:11
Hi James.
This is quite an easy fix - remove the side of R2's battery box of the foot making the noise & check the white wheel with the black rim on the back of the motor - they work loose, and you'll probably find it will come off quite easily.
All you need to do is add a small amount of superglue to the center of that wheel and re-attach - leave for about a minute (or longer if you want).
Once everything is re-attached your problem should go away.
Cheers!
Darin
#6 Posted : 02 January 2019 21:21:09
Always good to hear of a successful build, very well done....Cool Cool
James H
#7 Posted : 02 January 2019 21:28:41
Here's a quick video.
Quite difficult holding one phone to control and another to video! BigGrin
R2 video
#8 Posted : 02 January 2019 21:41:17
Excellent. WTG
Cool Love Cool Love Cool
DC-Zol.
#9 Posted : 02 January 2019 23:22:11
R2 video
Definitely the wheel on the back of one of your motors has worked loose & making that noise!
James H
#10 Posted : 03 January 2019 09:06:52
R2 video
You had the same problem?
DC-Zol.
#11 Posted : 03 January 2019 14:11:56
James H wrote:
R2 video
Hi. Had less of an issue but same noise on left leg motor - it's worth checking as it's only 4 screws.
the flywheel seems to be only a push fit, so when R2's motors go full speed the flywheel continues to move when R2 stops. the little bit of superglue will help it remain on the (round) shaft
James H
#12 Posted : 03 January 2019 16:16:57
That's fixed it!!! Many thanks!
Now 100% glitch and operational-error free!
DC-Zol.
#13 Posted : 03 January 2019 16:18:35
Great!Cool
This page was generated in 0.274 seconds.
