7 Pages «<23456>»
Nems Gulf War Tornado in flight. Options
#61 Posted : 02 January 2019 23:22:19
The front and rear fuselage are now glued together, and now I remember why I stopped building aircraft, the fit was awfulCursing LOL !! Ok well, nothing a bit of filler wont fix!LOL
#62 Posted : 02 January 2019 23:38:51
BigGrin Looking good though, I had seen and heard of many reports of the fit problem, so I squared up both the upper and lower rear fuselage halfs then glued the lower rear fuselage to the nose 1st and then attached the upper half, a bit long winded but it stoped the 'gap' formingCool
#63 Posted : 02 January 2019 23:46:02
Very nice Nem, looking really good....Cool Cool
#64 Posted : 03 January 2019 00:12:57
Looking great Nem,
I didn't get too much of a gap as noticed a little creep early so added a slither of plastic strip and smoothed it out before joining. My main problem was the profile behind the cockpit. It seemed to be slightly different in roundness.
Taking shape though.
Chris
Cool
#65 Posted : 03 January 2019 00:15:19
magpie1832 wrote:
Looking great Nem,
Chris
Cool
Hi Chris and thanks for looking in. The profile behind my cockpit is spot on, its either side I have gaps, nothing some Mr Surfacer 500 wont cure!BigGrin
#66 Posted : 03 January 2019 23:56:46
Air brakes fitted, wheel well covers fitted and the air intakes. Thank whoever for Mr Surfacer! This kit was not designed to be displayed in flight even if it does give you that option, the parts are a lousy fit!!Cursing LOL
#67 Posted : 05 January 2019 21:43:50
Filler work on the fuselage is finished, panel lines scribed and the tail is fitted. One that is dry I can sort of the gaps and get on with the rest of the build.Cool
#68 Posted : 05 January 2019 22:08:44
Nice job with the filler. Looking forward to the next update.
#69 Posted : 05 January 2019 23:20:05
Coming along nicely. Look forward to seeing more.
#70 Posted : 05 January 2019 23:36:18
Thanks for looking in and your comments everyone.BigGrin Cool
Weapons pylons are now fitted.BigGrin
#71 Posted : 08 January 2019 13:13:55
The initial build is done, time for primer. Weapons load will be built and added at the end along with the seats and canopy. Next major part is to to find a base the right size and desertize it!BigGrin Cool
#72 Posted : 08 January 2019 13:45:17
Looking good NemBigGrin you will need a fairly big base for it.
#73 Posted : 08 January 2019 13:56:10
Yeah, 50x30cm minimum!Blink LOL
CaptnBirdseye
#74 Posted : 08 January 2019 18:08:27
Rank: Superelite
Yeah but 'with the scale, you get to see the detail'BigGrin
#75 Posted : 08 January 2019 20:56:15
Looking great Nem, look forward to the paint going on.
Chris
#76 Posted : 08 January 2019 22:02:36
Thanks all for looking in and your comments.BigGrin
Base is ordered, it's a butchers block, all will be revealed!!LOL Cool
I have given the Tornado a coat of white primer all over and this is for a few reasons, 1. it shows all the panel lines really well so I can scribe any I missed, 2. it shows any defects that may still need work, glue lines and gaps and 3. its easy to pin wash the panel lines before the pre shade and top coat.Cool
#77 Posted : 09 January 2019 15:13:07
My display base arrived, lovely teak chopping board for me to drill holes in and cover in glue and paint!LOL Cool
#78 Posted : 09 January 2019 17:46:41
Blimey, that's a beast of a display base Cool
#79 Posted : 09 January 2019 19:08:27
Crying Crying
I can see a few domestics breaking out here as chopping boards go missing from kitchens all over the country. LOL LOL
One good thing though Nem is that it won`t tip over, just gonna need a big shelf.
Are you going to dio the base?
#80 Posted : 09 January 2019 19:45:24
That's a substantial looking base BigGrin liking the angle the aircraft is placed at as well.
7 Pages «<23456>»
This page was generated in 0.294 seconds.
