Finally got to complete my R2 build last night.
Testing this morning I find the following failures:
1) No leg ultrasonics - but central ones work 2) No R/B led at the front of R2's head 3) Light sabre doesn't operate - seems dead.
All of these things worked during the build test phases.
I've reviewed the wiring and it looks ok.
Wondering if anyone has experienced similar issues or has some guidance?
Best regards Paul
Firstly, can you provide a link to the batteries you purchased?
Hi can you check the button tops are making good contact with the + end of the battery box terminals and did you buy them between mid Nov to 10th Decemmber. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
