possible battery box problem Options
corelki2005
#1 Posted : 04 January 2019 19:58:14
First of all I have these batteries
Batteries
I have fully charged them.
Although I haven`t got the last 4 issues yet, should be any day now, I thought I would inset them in the box (its not connected to anything) and measure the voltage across the terminals as a test. Herein lies the problem as I thought it should be around 12.5v but am only getting 4.2v, is this correct or do I need to get another battery box?
Nick
#2 Posted : 04 January 2019 20:17:00
Check that your batterys at the + end are making full contact with the battery box terminals. When you say tested the terminals you meen the terminalsat the end of the lead.
corelki2005
#3 Posted : 04 January 2019 20:48:25
Have just re-inserted the batteries and retested across the battery terminals I get 12.4v which is correct but at the lead end I now get 0v, whereas last night I had around 4.2v
stwood6
#4 Posted : 04 January 2019 21:28:31
Rank: Beginner Level 3
I'm still a few issues from completion too, but saw your question, so I decided to try it too. My battery box is doing the same - 12.6v across the battery series, 0v out on the power cable.
But based on the start-up sequence that we need to perform on R2 the 1st time - I'd expect 0v out until the battery/charger circuit is initiated. If it was putting out the 12.6v already there wouldn't be a need for the start-up sequence.
So I'm thinking this is normal at this stage of the build.
Current Builds: R2D2, Millenium Falcon
#5 Posted : 04 January 2019 21:34:57
Yes that is correct as it needs switching on first so wait until your R2 goes through the start up procedure.
This page was generated in 0.269 seconds.
