LG MJ1 Batteries? Options
MadManMick
#1 Posted : 04 January 2019 20:25:35
Rank: Beginner Level 3
Hi all. After trying to source the Samsung 3OQ batteries in the UK with no luck and with the lack of any battery offer being made available yet, I have decided to go ahead and purchase some Lg Mj1 batteries (more expensive!). I was waiting for the offer but seeing R2 just sitting there completed but not doing anything for nearly 3 weeks and also not knowing if any bits are faulty I couldn't wait any longer!
I just wanted to know if anybody has used these successfully. The specs are:-
Battery Size : ∅18.35mm x 66.30mm
Nominal Voltage : 3.635V
Nominal Capacity : 3500mAh
Min. Capacity : 3400mAh
Charging Method : CC/CV 4.20CV ±0.05V
Discharge Voltage : 2.50V (Average Cut Off)
Standard Charging Current : 1700mA , 0.5C
Max. Rapid Charging Current : 3400mA , 1C
Standard Discharge Current : 10A
Operating Temperature : Charge : 0 to 50°C Discharge: -20 to 60°C
Storage Temperature : 1 year : -20~25°C 3 months : -20~45°C
Battery rate : 3C
Weight : 50gr.max
Colour : Lime Green
Version : Button Top
Protection Circuit Board / PCB : No / Unprotected
Type : Rechargeable
Chemistry : NMC / Li(NiMnCo)O2
Do these look OK? They were bought from Ecolux on this link :- https://www.ecoluxshopdi...-3500mah-button-battery
Cheers
Mick
#2 Posted : 04 January 2019 21:41:31
They look like they meet the requirements needed with the 10 amp continuous discharge figure, all you can do is try them.
MadManMick
#3 Posted : 04 January 2019 22:23:40
Many thanks for your quick reply, fingers crossed then !
This page was generated in 0.321 seconds.
