Wow, you’ve got your work cut out there Derek. Great kit. You might want to try the flickering LED,s, different from flashing. I used them in the Podracer dio for the engine. Very effective and could work with what you are doing. Mark Regards Markwarren (Mark) Admin
Markwarren wrote:Wow, you’ve got your work cut out there Derek. Great kit.
Mark Thanks Mark I have flickering leds on order and was going to experiment connecting one to two consecutive pulses from the IC outputs to work a flickering led for longer as I will have spare outputs. The good thing is that I can fit the electrics late in the build so have plenty of time to experiment and I have purchased a breadboard for testing so its a case of plugging components in/out rather than soldering. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Great stuff its here and have fun with the build Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Glad that your items have arrived Derek, looks like quite a well thought out and comprehensive diorama that you have there with a lot of individual kits in one box. Should build into a fab diorama especially with all of the flash/bang electronics that your going to install!
Good luck with the build, looking forward to following your diary.
Kev  Per Ardua Ad Astra
Now update time for this one and all has not been good news since the last post. When I opened the sealed kit originally I made the assumption that everything would be present and correct. Must stop making assumptions. I have primed the dio base and will put base colours on prior to adding sea colours, real sand and grass. To that end I have purchased basing sand and flock grass (OO gauge railway scenic materials). I have also started the basic construction of the gun emplacement that needed lots of flash removing before the interlocking parts would fit. It was when I primed the Sherman tank that I noticed a gap on the sprue where a hatch should be. Like I said when I purchased the full kit it was all sealed in its individual bags. Not till I opened the Sherman bag did I realise there was a part missing, so went to ebay and picked up a replacement kit. As you can see in the last pic I now have a Sherman kit to replace a tiny hatch. Hey Ho, these things happen. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi coming on well ,look forward to more ,cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Glad you managed to source the missing hatch Derek, though not the cheapest fix, you must have been quite annoyed? Looking forward to seeing the scene unfold as the build progresses.
 All looking good and lots of goodys there Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice one Derek, glad you got a replacement. You’ve certainly got your work cut out with that scenery. Mark Regards Markwarren (Mark) Admin
Looking good Derek. Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Good work there Derek!  Are the two hatches identical? If you haven't tried it before I can strongly recommend getting a small 'starter kit' of silicone rubber and acrylic resin - for a few pence you could make a mould from the hatch you had and cast a resin one for the one that was missing! Too late now but it saves pounds for the future! Best of luck! Robin First wooden ship: The Grimsby 12 Gun 'Frigate' by Constructo Second: Bounty DelPrado Part Works Third: HMS Victory DelPrado Part Works 1/100 scale Diorama of the Battle of the Brandywine from the American Revolutionary War Diorama of the Battle of New Falkland (unfinished sci-fi), Great War Centenary Diorama of the Messines Ridge Assault Index for the Victory diary is on page 1
Many thanks for all the comments and tips, much appreciated. Update on the scenery: Have applied the initial colours to the base and added the beach sand. Also painted the main section of the gun emplacement and added the flock grass around the base. That`s all for now. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Nice work Derek, coming on very nicely. Mark Regards Markwarren (Mark) Admin
Looking good Derek. Doing a good job on the diorama. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Hi Derek,coming along very well, and with the sand effect and waves will look very affect. Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Looking good Derek, making very nice progress.... Regards Alan
Looking really good Derek. The sand and grass make all the difference! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Thanks to all who looked in and for the nice comments. Small update on the LCM landing craft while I`m on with fitting the gun emplacement to the dio base and blending them into each other. The main assembly of the craft went together very well. I then started on the three figures of the crew. One of the crew is stationed inside the cabin area and that`s where some issues arose. The crew member was a perfect fit to the height of the wheel in the cabin, but the windows were above the crewmans head and the side windows were also behind him so he could not actually see through any window. So after a cut and shut job I`ve managed to get the windows in the correct position. That`s all for now. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Nice bit of work there Derek got round that one ok. Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
tf64 wrote: Nice bit of work there Derek got round that one ok.
Trev
Thanks Trev, Not a hard fix, but me thinks it`s one that should not have been needed. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
