2 Pages <12
'Fighting top' Ribs! Options
doremi495
#21 Posted : 22 July 2011 16:23:43
Mike Turpin wrote:
According to Longridge, the reinforcing ribs in the fighting top were usually 4 inch wide and about 4.5 inch thick at the rim, tapering towards the hole in the centre. That's a dimension of about 10 cm. When you scale this down, you get a figure of about 1.2 mm. so I would suggest that 2mm x 5mm is the wrong timber to be using.
Mike T
Hi Mike,
I too am having a problem with the size of the fighting top ribs. I think they are completely out of scale. I have searched the Internet for photos and diagrams of the fighting tops, and the best I've come up with are the Jotika HMS Victory plans. Jotika use 1.5 X 1.5 strips for the ribs. The Jotika kit is 1/72 scale so I am thinking of sanding down 1.5 X 1.5 strips to 1.2. This fits in with your post.
(Stands back and waits for howls of outrage.)(not from you Mike!)BigGrin BigGrin BigGrin BigGrin
Dave H
Current builds :- Hachette 1/16 Tiger Tank
H.M.S Victory, Santisima Trinidad (Section), 1/8 scale Aston Martin DB5, 1/8 scale McLaren, YNWA
#22 Posted : 22 July 2011 16:38:29
In that case you might also want to ponder changing the dimensions of your the hull planking and decking, but at the end of the day your building how you want it, which is down to personal choice and can't be a bad thing.
doremi495
#23 Posted : 22 July 2011 17:12:45
I appreciate your point Mr T, but the thickness of the hull and deck planking can't realy be seen like the fighting top ribs.
Dave H
#24 Posted : 22 July 2011 17:38:26
It is planking & decking width rather than thickness that I was talking aboutWink
doremi495
#25 Posted : 22 July 2011 18:40:54
Oops,never thought of thatBlushing
Dave H
2 Pages <12
This page was generated in 0.037 seconds.
