80 Pages «<3031323334>»
#621 Posted : 10 January 2019 09:46:46
Beautiful Phil, top class work....Drool Drool
Sticky Wickett
#622 Posted : 10 January 2019 10:23:00
Thank you very much Alan!BigGrin
Phil W.
#623 Posted : 10 January 2019 10:45:42
The PE looks excellent, nice detail.Love
Sticky Wickett
#624 Posted : 10 January 2019 13:15:49
Cheers Mark!Cool
Phil W.
samson
#625 Posted : 10 January 2019 15:29:59
It is a cool model with many details in love it Cool
Sticky Wickett
#626 Posted : 10 January 2019 17:12:31
Thank you Jens!Cool
Phil W.
Kev the Modeller
#627 Posted : 10 January 2019 20:55:24
Really getting to the nitty gritty now, with some nice details starting to be added. Will look fab when it's all painted. ThumpUp
Bet the fitting of all of those thousands of rivets to the hull seems like a very long time ago now eh Phil?! Blink
Per Ardua Ad Astra
Sticky Wickett
#628 Posted : 10 January 2019 23:44:41
Thank you Kev!Cool Yes, it's starting to take shape now.
Ah, the riveting!Flapper LOL Those were the days! lol
I still have a bit more riveting to do though when I build up the rudders, fore-planes and aft-planes, but that won't be for a few weeks yet.
Phil W.
Sticky Wickett
#629 Posted : 17 January 2019 09:02:17
Good morning from 'The Dockyard'.
This week continues with the addition of part-works supplied items to the conning tower.
The first step was to prep the conning tower hatch by which all look-outs would gain access to the bridge.
The only thing that I didn't like about the moulded plastic hatch was the spring. So i decided to cut this section out and replace it.
The attached photo shows the moulded plastic spring removed.
Sticky Wickett
#630 Posted : 17 January 2019 09:03:25
I then drilled through the hinges and fitted a small length of 1.5mm diameter brass tube.
Sticky Wickett
#631 Posted : 17 January 2019 09:05:37
To fabricate the spring, i used a piece of solder wound around the brass tube and cut to suit. I then completed the hatch with the part-works supplied PE.
Sticky Wickett
#632 Posted : 17 January 2019 09:06:59
Hatch in position, not glued at this stage as i will paint and weather it separately before fixing it permanently.
Sticky Wickett
#633 Posted : 17 January 2019 09:12:24
I then made up the search periscope mast housing as per the part-works instructions. Similar to the hatch, this will be painted and weathered separately before fixing in place.
Sticky Wickett
#634 Posted : 17 January 2019 09:17:57
I then made the attack periscope mast housing and will paint and weather as a separate item.
The difference between the search and attack periscopes is that the search periscope is binocular, while the attack periscope is monocular and thus smaller in cross section and less visible, hence its name.
Sticky Wickett
#635 Posted : 17 January 2019 09:20:07
The next item made as per the part-works instructions was the UZO; U-boat targeting sight.
Sticky Wickett
#636 Posted : 17 January 2019 09:22:10
The attached photo shows all of the masts and periscope housings temporarily fitted to give an idea of how they will look. As I've mentioned before, all of these items will be painted and weathered separately prior to fitting.
Sticky Wickett
#637 Posted : 17 January 2019 09:24:31
From another angle.
Sticky Wickett
#638 Posted : 17 January 2019 09:26:22
Well that concludes this weeks update. Stay tuned for more work in progress next week.
Thanks for looking in and your comments, have a great weekend and happy modelling.
Phil W.
#639 Posted : 17 January 2019 09:59:27
Looks amazing, detail being applied is superb.....Drool Drool .. Another great update Phil, well done....Cool Cool
Sticky Wickett
#640 Posted : 17 January 2019 11:06:58
Thank you very much Alan!Cool BigGrin It's very satisfying when the small details are fitted, bringing the model to life.
Phil W.
Guest (44)
This page was generated in 3.701 seconds.
