Projector Lights up but no video Options
Deredeo
#1 Posted : 11 January 2019 13:45:25
Rank: Newbie
The rest of the functions seem to work fine so far but when I use the projector I get a beam of light and the voice over for Leia or Luke in full, however the picture is missing. I do get a circle of light but no image of any kind, I've taken it apart and double checked the cabling and that seems to be fine.
Any ideas guys?
PeterP
#2 Posted : 11 January 2019 16:18:35
Did you test the projector after you assembled it? sounds like you may probably need a new projector display screen and circuit board from issues 27 contact C/S the number is on the inside of the cover
Bobbaf3nn
#3 Posted : 11 January 2019 16:52:22
Good luck getting a replacement issue 27 .. When i requested one deag advised out of stock
Probably selfish people requesting them first time around to get spares or thinking it was faulty because it only displayed one hologram
#4 Posted : 11 January 2019 18:54:44
Hi try replacing the circuit board from Issue 27 first.
shunte
#5 Posted : 18 January 2019 11:56:46
I have the same issue, it did work for both holograms before it was all connected, my camera also doesn't work so I need two replacement issues, the connection to the lightsaber ejection tube motor is also weak, I'll try soldering that first.
matt4tay
#6 Posted : 15 February 2019 15:37:07
Rank: Newbie
Also having this problem. Everything works perfectly except the images.
I just get a large white circle.
#7 Posted : 15 February 2019 20:40:12
You need a replacement issue 27 contact C/S for one.
This page was generated in 0.365 seconds.
