Dome moves too fast Options
Jonnyc1988
#1 Posted : 12 January 2019 18:19:18
Rank: Beginner Level 1
So I had an r2 that the red light would come on but didn't do anything else. So I ordered a new mcu which arrived today and after a full afternoon replacing it I have powered r2 up and his dome spins too fast. Is there a fix for this? Thank you
#2 Posted : 12 January 2019 19:41:59
Double check the wires too the head motor are fully seated and making good contact.
ckember999
#3 Posted : 12 January 2019 21:34:28
I have the same problem, after power up the dome slams one whether the other, then doesnt center. I have a new mcu on order as checked all the connections several times. everything else works, except he doesnt move his head when asked to shake it in the app or when on patrol. it moves fast when usig manual mode In the app.
#4 Posted : 12 January 2019 21:59:40
You’ve notes the same across 3 members topics, can you please create your problem topic rather than repeating the same into other members topics. Hopefully the MCU swop will resolve your problem.
Thanks
Jonnyc1988
#5 Posted : 13 January 2019 13:18:42
I've just fitted a new MCU so hope it's not that again! Heard some people say it might be a faulty dome motor?
#6 Posted : 13 January 2019 13:32:39
That’s the next thing to swop if the MCU swop does not resolve it and double check that the wiring between the two is secure/has good connection etc.
This page was generated in 0.124 seconds.
