these are the second lot of batteries i have purchased ans r2 still doesn't work, i only get the led lights at the back of the dome, plese help this is the battery link https://www.banggood.com...der&cur_warehouse=CN
The first thing to check is to make sure the batteries are making good contact in the battery box. If you have access or you can borrow a volt meter, unplug the battery box and check the voltage from the larger black ended cable which has a positive and negative terminal. If all okay you should get 12.3v reading. Thoroughly check all cables are correctly located and making good contact. Here is the troubleshooting guide to help. https://forum.model-space.co.uk/...aspx?g=posts&t=30247Regards Markwarren (Mark) Admin
Thanks for the quick reply mark, are the batteries ok? i have checked all the wiring twice, and all looks ok, will check voltage tomorrow and let u know, do i just post reply on this thread?
Yes just post in this thread, as it is your troubleshooting topic. The tops of the batteries you have from what I can see in the link you’ve provided are vented ones. Some people have had issues with this type as some do not make a good contact in the battery box, not saying yours don’t, which is why I would like you to check there first. Regards Mark Regards Markwarren (Mark) Admin
The batteries are fully charged and I’m getting 12.3v across the corners of the battery box but nothing coming through the power lead, do u think I need a new battery box? If yes how do I go about ordering?
Order a replacement battery box from c/s. The number is on the inside front cover of the magazine. Mark Regards Markwarren (Mark) Admin
finally got a new battery box, i have 12.3v coming out it but r2 still does nothing, any suggestions?
Hi Can you tell me exactly what is happening, when you say nothing, is there any lights on the dome. Just that I’m not in front of your R2, so just trying to go through a process of elimination. Also have you done the correct startup procedure as instructed in the user guide, as you now have a new battery box and that will need to be primed. The link for the user guide is below if you need it. Also check all cables are corrected positioned and pushed in fully. If you can attach a small video of you staring him up, that would help. https://www.model-space.com/gb/a...v=-&__utmk=268708146Regards Mark Regards Markwarren (Mark) Admin
i have checked all cables and done the start up again, theirs nothing to video the only thing i'm getting is the led lights on the dome come on and two blue lights on the legs
any suggestions mark, whats my next move??
At least you’ve got the right voltage coming through. The next step would be to order a replacement MCU that came in issue 94. Just make sure all the cables are firmly in the right place and the right way round when you get it. You will also have to do the start up procedure again with the new board. Regards Mark Regards Markwarren (Mark) Admin
ok i will try that, is their any reason why so many of the main parts are faulty, all the other posts with problems need another MCU?
Joined: 13/07/2018 Posts: 41 Points: 141 Location: Slough
Compared to how many kits have been sold, the number of faulty boards is probably very small - within normal tolerances of a large production, I would have thought from the proportion here.
As to why it's usually the MCU as opposed to other parts, think of the complexity of production. Making a motor, or a button, or even a projector, is vastly simpler than building an entire computer on a board, which is what the MCU is.
mark are you still with me? got a new MCU, fitted it, all cables seated correctly, went through the start up process again, still nothing? getting the same LCD lights on the head and 2 blue lights on the base of the legs? now what?
Guest (8)
