12 Pages «<45678>»
Lancia Delta Martini WRC 1991 + Lancia Delta Test car 1991 Hachette 1/8 Options
frah2o
#101 Posted : 16 January 2019 09:02:04
Second version of fan, I remade the new circle carter on fan structs
frah2o
#102 Posted : 16 January 2019 09:03:32
New step on radiator fan: I selfmade the heat shield to protect fan from turbo heating
frah2o
#103 Posted : 16 January 2019 09:05:39
Starting with a new hard project: the idea is to remade totally the interccoler duct that is completly wrong by hachette
Courtesy of Scara73
frah2o
#104 Posted : 16 January 2019 09:06:52
First part of work on intercooler duct
frah2o
#105 Posted : 16 January 2019 09:09:27
Some trouble with new duct, To fix it i must reshaped the lower side.
I self made the missed hose from turbo to intercooler
frah2o
#106 Posted : 16 January 2019 09:10:58
I strated the first step work with milliput to reshape the new hose and turbo housing.
And the comparison with mine modify and the stock unit
frah2o
#107 Posted : 16 January 2019 09:13:09
Some extra work with milliput on turbo and some little dtails on exhaust manifold.
frah2o
#108 Posted : 16 January 2019 09:15:24
Strat work on electrical. I remade the coil on struts bar and made some work on plug wires
Courtesy of Scara73
frah2o
#109 Posted : 16 January 2019 09:17:22
Some fitting test and i adding the future connector for extra electrical cable (injectors and some sensor)
frah2o
#110 Posted : 16 January 2019 09:19:05
Some extra work to made the filling hose for gerabox oil that it was completely missed.
Courtesy of Cheral Auto
Courtesy of E-wrc
frah2o
#111 Posted : 16 January 2019 09:21:47
Some fixxing tips and new water hose.
New fixing plate for water pump on timing carter
Selfmade clutch lever and clutch cylinder
frah2o
#112 Posted : 16 January 2019 09:23:39
FInally i started with painting.
The original engine is painted with a special grey haze
Courtesy of Facebook page: Assistenza Lancia Martini.
frah2o
#113 Posted : 16 January 2019 09:24:47
Start to add some little datail and painting detail
frah2o
#114 Posted : 16 January 2019 09:27:05
repainted the rocker cover and oil sump.
Some extra detail painting and first fitting test on chassis.
For the moments it'all, i hope to enjoy you
Sticky Wickett
#115 Posted : 16 January 2019 13:16:28
Amazing detail!!!Love
Phil W.
#116 Posted : 16 January 2019 21:28:40
Great mods going into this buildCool superb work.
frah2o
#117 Posted : 07 February 2019 09:20:52
frah2o post_id=469423 time=1548321266 user_id=3882 wrote:
I finished the work on cooling raditor for gearbox and powersteering.
I must raise the bracket to fit the modify radiator.
Also i modify the front headlight bracket to have possibility to fit the bumber with body fixed.
frah2o
#118 Posted : 07 February 2019 09:46:23
I started the work of idraulic hose and i selfmade new joint for lubrification
frah2o
#119 Posted : 07 February 2019 09:48:19
Carbon work on airbox and extra add to powersteering reservoir.
frah2o
#120 Posted : 07 February 2019 09:49:27
Here the work befoere the final clear coating
Terminata la prima fase dei cassoncini filtro aria, steso tutto il carbonio. 2-3 giorni di essicatura vapori da fissante e ammorbidente e poi trasparente, poi dettaglieró le 4 clips del coperchio e gli ultimi dettagli.
Ho cercato di dare il mio massimo per dare un pó di dignità al cassoncino del filtro aria e mi sembra di aver fatto un lavoro guardabile.
Ho appoggiato il tutto nel vano motore e mi sembra abbastanza accettabile
Nel frattempo finito l’extra sui serbatoi idroguida e sul nuovo raccordo autocostruito per la lubrificazione del cambio differenziale.
Guest (6)
12 Pages «<45678>»
This page was generated in 0.357 seconds.
