Looking good Derek, it'll be interesting to see the PE parts being added.
Well done.
Kev  Per Ardua Ad Astra
Kev the Modeller wrote:Looking good Derek, it'll be interesting to see the PE parts being added.
Well done.
Kev  Cheers Kev The interesting bit will be if I can "see" the etch bits. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Well time for an update, but firstly thanks to all who have looked in. Have dealt with some of the etch with reasonable results: The replacement foot pedals are in with one set painted to show the difference. I have also gots the seats ready for the seat belts, along with the cockpit consoles ready to be installed. Made up and ready for a coat of paint are the rear control stick and a small replacement box for the one removed from the rear bulkhead. (More on that in the next update). The final pic for this update shows the side panels for the cockpit. Part 22 on the left will have the control levers added in the large silvery square and a very small etch switch in the smaller one. On part 24 you can see a box section that I have added already. More soon. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Nice update Derek  the cockpit is coming together nicely. Al
Excellent update, cockpit is really coming along.
 Nice work Del
Nice cockpit detail, worth the time and effort, well done.
The cockpit is coming along nicely Derek. Great looking instruments. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Lovely progress Derek, cockpit is looking the biz..... Regards Alan
Apologies for the overdue update but here we are. I`ve fixed all the panels and consoles into the cockpit area. Got to grips (very carefully) with the etch seat belts and have fixed the rear seat in place. Last couple of belt parts to fit to the front seat and then that can be fixed in place. Had my very first ever play with resin parts  and fixed them together after ages of cutting and filing/sanding. I`m happy with the result for a first attempt. Proof of the pudding is in the pics below. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Lovely work Derek, fantastic bit of work, they look amazing. Mark Regards Markwarren (Mark) Admin
Nice work Derek, looking good. You've done a great first-time job with both the PE belts and the resin exhausts too.
Well done.
 Nice work with the PE Derek  and i know what a pain resin can be if you've never used it before. So well done. Regards Gray
Looking spot on Derek. very well done Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Great work Derek, you've done a great job with the PE and look forward to paint on them nozzles. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Lovely work Derek, its all in the detailing and its looking fab..... Regards Alan
Lovely work on the cockpit Derek Al
 All looking good and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
