Head still spins too fast Options
Bigfoot651
#1 Posted : 17 January 2019 17:17:23
Rank: Beginner Level 1
I Still need help. I have had problems with the completed R2. When I power up the head slams to the left, then right and does nothing. If I disconnect the head motor, which works on the test board, and turn the head manually it works fine (minus any head movement). I have contacted Deagostini and they replaced the MCU, which arrived today. I have just fitted the unit and I am getting the same results. I have checked the cables so many time I could do it blindfolded now. can anyone suggest what I do next, please?
#2 Posted : 17 January 2019 21:15:26
Hi ask for a replacement head motor from C/S.
Fergin
#3 Posted : 23 January 2019 18:44:36
Hi m8
Exactly the same issue as you spent a few hours replacing mcu and issue exactly the smae
I had a spare motor that i got when i thought that was issue, replaced motor and now working as it should do
Might be worth trying that as it fixed it for me
Fergin
Bigfoot651
#4 Posted : 24 January 2019 16:59:35
Thanks Fergin.
It's nice to know that replacing the motor could fix the problem. I have ordered a replacement, just waiting for it to be delivered.
David
Bigfoot651
#5 Posted : 09 February 2019 18:47:48
Just to confirm replacing the motor solves the problem
This page was generated in 0.145 seconds.
