A quick mock up of the rear frame, gearbox, rear mudguard and fuel tank. Nemesis attached the following image(s):
Looking good Nem, it doesn't go together as well as a Tamiya kit but your making it look like it does Al
That’s coming on very nicely, great work. Mark Regards Markwarren (Mark) Admin
Thanks for looking in and your comments everyone. Rear frame is now completed, and is now in primer along with the fuel tank and gearbox. Nemesis attached the following image(s):
Looking good in the primer Nem,  taking shape nicely now Al
I quite like the green in your mock-up photos, but i guess it's not authentic? I do like the look of this kit
CaptnBirdseye wrote:I quite like the green in your mock-up photos, but i guess it's not authentic? I do like the look of this kit Thanks for looking in. The green you see is the plastic colour, and not authentic. There is a big myth that everything the Allies had on the ground was the same olive drab, and it is as far from the truth as you could get. There are about 40 different shades of olive drab used in WWII. The colour I am using is based on the actual colour Triumph painted them from the factory, I spoke to owners at bike shows and meets and have quite a few reference photos to help me. Nemesis attached the following image(s):
Rear frame, fuel tank and gearbox are painted, the gearbox is a dry fit as I need to paint the mount and it also need some adjustment to fit in the frame properly. Tank and frame will now get a klear coat. Nemesis attached the following image(s):
Coming together nicely and getting an impression of size
Thanks Tom, it is going to be a decent size. All parts have now been sealed and once fully dry I can fit the gearbox into the frame. Nemesis attached the following image(s):
Great job Nem, its looking the part now.
 Coming together nicely Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice work, looking excellent. Mark Regards Markwarren (Mark) Admin
