Linda4bert Options
Linda4bert
#1 Posted : 18 January 2019 10:03:53
Rank: Newbie
How long do you charge the batteries in r2d2 once he is working, and do you have him turned on or off?
#2 Posted : 18 January 2019 11:00:39
R2-D2’s front and rear status displays light up in different colours to display as his activity or status changes.
You can charge R2-D2 whether his power switch is turned on or off. If he is powered up, his front status display will change colour to show the progress of his charging as noted below, but make sure your R2 is not able to move around.
Turn R2-D2 to access the power socket just ahead of his middle leg. Plug the mains adaptor into the hole and leave it until he is fully charged.
If R2-D2 is powered up while he is being charged, the front status display will slowly flash purple.
When he is fully charged, his front status display will turn solid blue.
When the level drops below 20%, his front status display turns red. You should not fully deplete the batteries or store R2-D2 in a state of total discharge if he is to be dormant for any length of time, as this may prevent the batteries reaching full recharge capacity.
There is a full R2 User Guide which can be found here:
https://www.model-space..../download/file_id/4316/
This page was generated in 0.306 seconds.
