10 Pages <12345>»
Ant62 victory build Options
Ant62
#41 Posted : 18 January 2019 15:16:48
Another side pic of the launch with tiller....
The arm on the tiler is a tad high but as a first attempt im happy....
Ant62 attached the following image(s):
Building.
HMS Victory.....
Corel Albatross 1840......Completed
Hindenberg Zepplin museum piece..Completed
Artesian Latina Sopwith Camel.....Completed
Bismark.........
#42 Posted : 18 January 2019 23:47:52
Making good progress Ant, nicely done...Cool Cool
#43 Posted : 19 January 2019 09:43:40
Looks like your enjoying this, well done Cool
#44 Posted : 19 January 2019 11:02:02
Nice work Ant, the launch looks very good.
Chris
Ant62
#45 Posted : 19 January 2019 17:33:07
Happy to announce that the launch is completed.
Rope coiled.
Anchor painted.
Oars painted.
Mast tappered trimmed and the tip painted...
Tiller put into the launch....
Only issue is have is that the oars seem short and of various lengthsMellow
Building.
HMS Victory.....
Bismark.........
#46 Posted : 19 January 2019 23:16:17
That's a great looking launch, well doneBigGrin
Erik A
#47 Posted : 19 January 2019 23:39:45
Nice work...
Current builds
HMS Victory
Endeavour longboat
#48 Posted : 20 January 2019 09:32:30
BigGrin Looks good to me and nice workCool
DaDokta
#49 Posted : 23 January 2019 13:21:37
Nice launch! Good work!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Ant62
#50 Posted : 16 April 2019 14:59:48
Hi all...
Well ive finally managed about 6hrs on Victory over the past 2 days..
Where does the time go when your engrossed in the build!!!!
Im at the level of the gun deck out of box 2....
So far so good........
Building.
HMS Victory.....
Bismark.........
Ant62
#51 Posted : 02 May 2019 17:38:31
Ive been quite busy on the build and managed to plank upto the bowformers and this where ive hit a problem perhaps im wrong....
On the offical build video which i have followed shows 11 planks up from the bottom of the lower deck to the bowformer this is the first picture...
The one below the i call 0(zero as it is below the deck)
The second picture shows my victory but from the lower deck upto the bowformers its only 10 planks...
The one below the lower deck i call 0(zero as it is below the deck)..
Help is appreciated to where i have gone wrong....
TBH i didnt see it as an issue until looked again at the video...
Planking as gone better than i expected...
If i have to remove the planks and start again i will do but it jave to be so carefully as not to damage any of the deck edges and the ribs..
Building.
HMS Victory.....
Bismark.........
Ant62
#52 Posted : 02 May 2019 17:45:09
Here is a full picture of what i have achieved so far...
Building.
HMS Victory.....
Bismark.........
#53 Posted : 02 May 2019 19:32:12
That all looks very nice so far.
Its amazing just how much build time there is in one of these models - certainly plenty to keep the hours flashing by.
Hope it all continues well for you.
Tony
Ant62
#54 Posted : 02 May 2019 19:44:42
Tony
It is certainly surprising how the hours fly by when you get going alright....
Building.
HMS Victory.....
Bismark.........
#55 Posted : 03 May 2019 06:18:38
BigGrin Very neat planking Ant lovely work Cool
Martyn
DaDokta
#56 Posted : 03 May 2019 08:13:36
This looks all very neat!
In my opinion there is no problem - every build is slightly different and you don`t have to stick to the words or in this case the number of planks every time.
As long as there are no gaps and the planks run in a natural curve - as is the case here - everything`s fine!
Keep up the good work!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#57 Posted : 03 May 2019 09:33:25
I think it all looks very good and very neat work throughout... You would be surprised at the variances you will find in the width of planks, they are at least 5mm wide and some can be as wide as 5.2mm and these small variances can add up as you lay more rows, this is part of the reason why all builds are slightly different. Important thing here is ensuring the first row of planks you lay is exactly where the instructions say and from there all of your markings are set correctly. With what I see I would carry on as you're doing but would suggest you post pics a little more often, this gives us the chance to spot anything that may cause you problems later in the build.... Looking good, very well done....Cool Cool
z8000783
#58 Posted : 03 May 2019 09:37:49
Groups: Unapproved
Nice work Ant.
#59 Posted : 03 May 2019 10:27:52
Very neat work Ant, all looking very nicely.ThumpUp
Ant62
#60 Posted : 03 May 2019 10:43:26
Thanks Gandale much appreciacted.......
I will add more pics but due to the download issue i had i couldnt but all is sorted now...
Building.
HMS Victory.....
Bismark.........
Guest (10)
10 Pages <12345>»
This page was generated in 0.284 seconds.
