Planking thoughts... Options
Ant62
#1 Posted : 21 January 2019 11:26:48
Like everybody else your thoughts eventually turn to planking and ultimately planking bending...
Im waiting on the electric plank bender to arrive which i ordered from model space nrly 2wks ago so i assume they are out of stock for thebtime being...
Anyway...
Im looking at the doing the following..
First im going to try the soaking method and then clamp the planks to the frame using the modified bull clips as i dont really want to use the pin method...
So letting the plank dry to see how it shapes after it dries out..
I have read about compression etc and i really dont want the planks to spit and then run out of planks...
Then again i have the electric plank bender to help just incase.....
Ive looked at jigs etc and Huh do i have the skill to make one!
Building.
HMS Victory.....
Corel Albatross 1840......Completed
Hindenberg Zepplin museum piece..Completed
Artesian Latina Sopwith Camel.....Completed
Bismark.........
#2 Posted : 21 January 2019 12:04:15
Have you considered plank bending pliers?
Ant62
#3 Posted : 21 January 2019 13:43:29
I will have them in my tool collection soon as a mate of mine as a pair and didnt know what they where until he sent me a pic and i then mentioned what they where for.....
Building.
HMS Victory.....
Bismark.........
Terry Benson
#4 Posted : 21 January 2019 13:51:50
Hi Ant
I had this problem on the stern of the Cutty Sark in which I tried soaking and bending only to split. in the end I made a jig from ply and nails and then laminated the plank using thinner planks.
Hope this helps
Terry
Terry Benson attached the following image(s):
On the bench. Cutty Sark 1869
Built. Mayflower 1609, Endeavor, 1768
#5 Posted : 21 January 2019 14:32:33
I find it depends on the material being supplied with the kit determines what method I use to bend planks. With the Victory I used bending pliers, soaking the strips and the electric plank bender, sometimes a combinations of all 3 methods were needed to achieve the bend required. It also comes down to personal preference and experience gained.
Ant62
#6 Posted : 21 January 2019 19:12:42
Terry Benson wrote:
Hi Ant
Hope this helps
Terry
Is that two pieces you are bending there terry....
Building.
HMS Victory.....
Bismark.........
This page was generated in 0.134 seconds.
