Joined: 10/01/2019 Posts: 15 Points: 57 Location: Boston
Hello, So I bought a full kit off of someone who didnt want theirs. I am missing a couple of pieces on issue 13 (picture attached) Do you know what these pieces are called and is there any websites that sell these spare parts or do I need to buy the issue? Also, is there anywhere I could buy extra screws or other small parts that come with the kit? Thanks.
Hi You can request the issue you need that contains the parts you wants by emailing to the email address below. They will be able to give you the cost as well. internationalshipping@model-space.co.ukRegards Mark Regards Markwarren (Mark) Admin
Markwarren wrote:Hi You can request the issue you need that contains the parts you wants by emailing to the email address below. They will be able to give you the cost as well. internationalshipping@model-space.co.ukRegards Mark Is there any place that just sells the parts and or screws? I am just missing 2 tiny parts. Wanted to just buy those parts and not an entire issue. Thanks,
You could try ebay, and there maybe be some spare screws in the Falcon kit. Thanks Mark Regards Markwarren (Mark) Admin
Joined: 21/01/2016 Posts: 38 Points: 114 Location: Queanbeyan, NSW, AU
If you go to a good hobby store you should be able to get some small diameter styrene rod/tube that you can substitute. How many screws do you need and which type? You may be able to get those at a hardware store or specialist fastener distributor. millenniummax123 wrote:Hello,
