3 Pages <123
Erik A Victory build Options
CaptnBirdseye
#41 Posted : 21 January 2019 22:32:51
Rank: Superelite
Looks nice and neat to me Erik ThumpUp
Well done
regards Gray
Erik A
#42 Posted : 22 January 2019 01:50:38
Thanks Alan
I do have a local website that supplies pins so if i need some it shouldnt be to much of an issue
Current builds
HMS Victory
Endeavour longboat
Erik A
#43 Posted : 22 January 2019 09:20:37
Stages 18 and 19 underway.
Erik A attached the following image(s):
Current builds
HMS Victory
Endeavour longboat
#44 Posted : 22 January 2019 12:13:50
Great progress Erik. Coming along nicely.
Chris
Erik A
#45 Posted : 03 February 2019 23:44:02
back from a week away so will get back into it tonight. BigGrin we had a bit of a heatwave while i was away so was expecting a bit of warping going on with the frames. but no worse than when i left.
Current builds
HMS Victory
Endeavour longboat
Erik A
#46 Posted : 06 February 2019 20:16:38
put the first part of the middle gun deck on and left to dry. when i went back to put the second piece on turns out i hadnt put it in correctly and the second piece doesnt fit. so i need to try and remove the deck piece and reseat it... trouble is im having issues with getting at the glue points.
it looks like the easiest way to do this is to remove the middle gun deck beams and then remove them from the deck piece. once i get the deck beams off i can soak the deck and beams in hot water to remove them. but getting them off is thehard bit
Current builds
HMS Victory
Endeavour longboat
Erik A
#47 Posted : 13 February 2019 20:31:59
thats a bit odd... the update i did yesterday didnt post...
anyway i managed to get the offending deck piece off by lots of hot water sponged and painted onto the joints. came off ok but needed cleaning up once the pieces were dry. re instated the deck beams and will re attach the decks correctly.
I must admit i was thinking of trimming the second deck side to make it fit. and re drilling the mast hole ie the easy option.
im glad i didnt
Current builds
HMS Victory
Endeavour longboat
Erik A
#48 Posted : 24 February 2019 20:31:59
attached the middle deck and when attempting to put in the deck beam it appears to require quite a lot of work to get it to fit in correctly.
Is this normal. the first set on the lower deck fit in quite easily . this set looks like i will need to take about 2 or 3mm off to get it to fit.
Current builds
HMS Victory
Endeavour longboat
Erik A
#49 Posted : 27 February 2019 21:12:28
all the middle decks glued in and should be finishing the deck beams tonight. then paint and start the fairing of the hull which will finish stage 20. i expect that the fairing will take a while Mellow
Current builds
HMS Victory
Endeavour longboat
Garth
#50 Posted : 02 March 2019 13:38:29
Hi Erik,
Nice update, looking forward to seeing your progress.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
Erik A
#51 Posted : 29 March 2019 20:45:27
I've jumped ahead a bit doing various stand alone pieces. Started doing the main and mizzen top pieces at stage 61 & 77.one of the parts is to put a bunch of ribs and the description in the instructions calls for use of a 1 x 5 plank to make these from. This the same for both stages. Is this a typo and should it be a 2 x 5 plank as supplied?
Current builds
HMS Victory
Endeavour longboat
Erik A
#52 Posted : 29 March 2019 20:47:11
Just found the answer here in the official build diary... and yes it's use 2 x 5. So must have been a typo
Current builds
HMS Victory
Endeavour longboat
Erik A
#53 Posted : 01 April 2019 21:07:04
foremast top, main top and mizzen top done pending the ribs on all of them. once complete and painted will post pics
Current builds
HMS Victory
Endeavour longboat
Erik A
#54 Posted : 13 May 2019 23:58:30
been a while since i posted. very little progress. work has been super stressful lately and find it hard to do anything when i get home. have progressed the fairing of the hull a bit and got the worst of it done just need to tidy it up now.
also found my glasses need changing as i find the little stuff very hard to see. have got a magnifying glass and light on order to try and solve this issue.
Current builds
HMS Victory
Endeavour longboat
#55 Posted : 14 May 2019 06:41:49
Erik
It is a pain with the eyesight i must agree.
Think i need to go get an eye test as i have a pair of reading glasses and a pair of distance specs but for close up i seem to get on better without either.
Do you have sny more pictures of your build. - would be good to see them.
Tony
3 Pages <123
This page was generated in 0.144 seconds.
