Joined: 25/01/2019 Posts: 3 Points: 9 Location: gloucester
I have been building the r2d2 since 2017 got issues 97 98 99 and 100 just before Christmas got the final model finished on Christmas Eve. My son had got me the batterys for Christmas so was unable to fit them he did let have one to test in the charger that came with issue 92 and I charged this battery ok On Christmas day I put another battery on charge hoping to charge the rest as the day went on I kept checking the battery and when it was charged changed for the next battery But it would not charge in fact it will not charge at all it will give me a charge level but that is all I have two batterys with a reading of 4.05 and three with 3.70 I put the batterys in the model to see if they would work But I did not read the bit in issue 100 about putting the charger in and turning it on for 2 seconds so nothing happened I have known tried putting the charger on for 2 seconds But still nothing happens I have checked all of the cables and they are connected correctly and all are ok Is it because the batterys are not fully charged
Hi could you post a link to where the battery's were bought from and the specs if you have them. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
RS pro of Bristol spec li-ion 18650 3.7 v 2600 mah
The only ones I can find on RS are these and there flat tops- https://uk.rs-online.com...able-batteries/7887261/
Can you confirm these are your batterys or provide a link to the ones you have or provide a photo of the battery you are using please. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 05/03/2017 Posts: 531 Points: 1,710 Location: Midlands, UK
well 2 not having any charge would give you issues of not turning on. Building: Ghostbusters Ecto-1, Ford GT40, Gone in 60 seconds Eleanor mustang, Shelby Cobra Complete: R2D2, Red Bull RB7 RC, Battleship Bismarck, Shelby GT500 'super snake'
I used 18650 lithium ion batteries 3.7 volt button top terminals no protection 2600 mah capacity RS stoke no 880-1558 brand RS pro from RS components i was only able to charge two of the batteries to full capacity showing a charge of 4.05 volt the remaining 4 show a charge of 3.70 volts i have a replacemet charger coming as in issue 92 could the low charge on 4 of the batteries be the problem what batteries did you use and where did you get them bgc attached the following image(s):
The problem is unlikely with the test charger.
You appear to have 2 faulty batteries but this aside, your batteries are indicated on the label as being “Protected” type which is incorrect for R2 use - they should be “Unprotected” (no protection) type, and therefore you first need to replace all of your batteries. Also there seems to be no spec info about the capacity discharge amperage of your battery which needs to be 3 Amps minimum.
A battery source can be found here: https://www.ecoluxbatter...30q-3000mah-15a-battery
If the RS Components webpage or your receipt, notes your battery as “no protection”, I would contact them for return/full refund as you have received “Protected” batteries as noted on the sleeve.
Links for the full User Guide and App info can be found here:
https://forum.model-spac...spx?g=posts&t=30359
Those batteries are very low power as 9watts/hour at 4volts equates to 2.25amps. Like Tomick has said if they are not charging/or not charging fully then it would also appear that you have at least 5 bad batteries.It also appears that they are protected flat tops. https://uk.rs-online.com...eable-batteries/8801558/
