Joined: 11/03/2010 Posts: 234 Points: 734 Location: Whelpley Hill, Chesham
Pack 1 arrived and in a nice Model Space box so well protected. Parts appear to be good quality and I would not expect anything else. Not a lot to do except fit the tank badges and join the tank parts together. Instructions say quite specifically use the Philips screw driver however, screw type "A" is a slot head, doesn't matter because there is no choice of screw to use but later on when we have more screws I hope this will be sorted out. It would have been better to have a cross head screw as the fixing is in a recess. Not moaning but worth pointing out. Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Adapt, improvise, overcome.
Now up to stage three. This is a large model but very detailed, assembly was straight forward and instructions very clear once I downloaded on my wife's MacBook Air as problem with iMac, details in site problem forum. One or Two holes needed clearing to accept screws but otherwise ok. Alec alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,277 Points: 22,138 Location: Northamptonshire, England
Nice start, looking good. Mark Regards Markwarren (Mark) Admin
 Looks good Alec  You're right, she's very large and heavy but that's how you get all that detail Keep it coming regards Gray
Hi looks good Alec ,some nice detail in this kit,cheers Mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Progressing nicely  its an impressive kit. Al
Thanks for looking in and the comments. Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Nice start Alec, great kit and up to the your usual high standers. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Great start Alec, looking good.
Joined: 17/11/2018 Posts: 13 Points: 42 Location: United Kingdom
When did you get your 3rd pack? Still waiting for mine
MasterRich wrote:When did you get your 3rd pack? Still waiting for mine Around 7th Nov Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
ok thanks I'll call them tomorrow to find out what has happened :)
Hi Everyone, Pack 4, Exhaust components, a little like the metal puzzles we had as children but a lot heavier. I found that the Lambda probes were a too tight a fit and wouldn't stay fully home, so I scraped the finish off the locating pin which allowed it to go fully home but then required adhesive but they are looking better that way. Worth checking which way around the springs look best as there are differences in the angles of the loops, I felt happier with adhesive on the spring plate pins as I'm not sure about access later in the build should one become loose. The head and cover is simple as is the dashboard. Alec alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
All looking good Alec, very nice update to your build.... Regards Alan
Another very nice informative update. Well Done. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Nice update Alec  I like how the exhaust system looks on this. Al
Pack 5 arrived a little late but no problem. Parts are up to usual standard and only slight adjustment to the small bracket that slides into end of radiator where some flashing required removing to enable a nice fit. The air box parts are stored until required later. Alec alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Looking good Alec Have to say, so far, this is a great kit
Hi Alec,this kit look's good model bikes are one of my favorite's and with the high standard of your build this will make a great display. Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Guest (6)
