PLank soaking Options
Ant62
#1 Posted : 27 January 2019 20:39:04
The planks for the Albatross im building as somebody said are sapelle wood and hard..
So i made a contraption for soaking them..
All compression fittings..
Length of 15mm copper pipe.
2 x 15mm straight couplers.
2 x 15mm blank ends.
Simple to do.
Attach a straight coupler to each end..
Then tighten a blank cap to one end n write a B (bottom).
Then attach the other blank end on and write T (top).
And a piece of pipe insulation...
There you have it..
Building.
HMS Victory.....
Corel Albatross 1840......Completed
Hindenberg Zepplin museum piece..Completed
Artesian Latina Sopwith Camel.....Completed
Bismark.........
This page was generated in 0.854 seconds.
