Joined: 26/12/2012 Posts: 140 Points: 418 Location: Plymouth
Really liking the look and detail on this the grey paint job really looks like its been weathered
Great progress on this Mark  those machine guns look superb and well worth the extra fiddling with. Al
Thank you guys for looking in and your comments. Thanks Andy, I’ll try that, should be easier to bend around. Mark Regards Markwarren (Mark) Admin
Looking really good now the paint is going on and nice work on the p.e, really makes a big difference.
Thank you a Nem and Kev, the pe certainly make all the difference. Mark Regards Markwarren (Mark) Admin
Looks clean and tidy Mark very well built. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
A little more done. I sprayed the craft with some chipping fluid before spraying it with a lighter grey. Using a very small brush I started chipping areas to give a worn effect. Doesn’t look much at the moment as the weathering will be done with oils and pigments once the main craft has been glued together. I also lightly sprayed with a rust brown over the entire landing craft, just to give a subtle inner rusting effect. The next step was to attach the cables to the crank and ramp pullies, now most of the airbrushing has been done. This was very fiddly.
The landing craft main three pieces were then glued together. I have left the ramp off for the moment as this will be easier to paint individually as well as easier access to the inner area. The decals will be applied next before the main weathering and colouring is done. More soon.
Looking really good, love the chipping effect. I use hairspray for mine, and also rock salt works well.
 Looks good to me and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Like this one Mark,you have put a lot of thought into your build and it shows. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Looking impressive Mark, nice work.
Thank you guys for looking in and all your comments. Mark Regards Markwarren (Mark) Admin
Now this is looking very impressive Mark, love the effect you're achieving..... Regards Alan
Thank you for your comments Alan, Ian. Mark Regards Markwarren (Mark) Admin
Hi looking good,very nice paint effect ,great work ,cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
