Kinchar Options
Kinchar
#1 Posted : 29 January 2019 02:45:35
Rank: Beginner Level 1
Hi all, from Downunder,
I'm building R2D2, quite impressed so far. Build with care checking document.
Australia seems last to know of this project. Aus. & NZ sites now don't exist.
Waiting for Issue39 at present. Available weekly, from a newsagent.
There may be a problem I found with ISSUE37, lightsabre ejector motor.
I checked small gear on the motor to see if it turns freely. It won't move at all.Huh . I tried with care.
I am unsure if it is just a normal motor (reversible) or something special.
Please advise if a dud and how to get it replaced.
Kinchar
mwstratton
#2 Posted : 29 January 2019 02:57:05
Welcome to the forums Kinchar
Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
#3 Posted : 29 January 2019 11:30:26
Hi Kinchar
Welcome to the forum.
The light saber operation is tested in issue 53 along with the leg sensors. At this point you can order replacements if needed.Should you require a replacement then you will need to request that via your newsagent.
This page was generated in 0.515 seconds.
