Thanks guys, much appreciated .
I've given the fuselage and the fuel tanks a go over with the green grey camo for the base coat(not done an amazing job as its mostly covered over) Then it will have a coat of Klear ready for some wear and tear effects. But not quite yet as need a few other things need doing first.
Chrismagpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Nice progress Chris  good to see one in the old Camo scheme. Al
 Good progress Chris  Coming on leaps and bounds. Well done
Coming on very nicely Chris, looks excellent. Mark Regards Markwarren (Mark) Admin
Thanks guys. @Spal It's not staying camo Al, the original GR.1 was painted this colour but when the gulf war kicked off they painted them quick over the camo. You can see it on various pics where the paint has worn off or chipped along the leading edges. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 Rank: Pro  Groups: Registered
Joined: 23/12/2018 Posts: 318 Points: 949 Location: Illinois, USA
Beautiful job Chris. Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
magpie1832 wrote:Thanks guys. @Spal It's not staying camo Al, the original GR.1 was painted this colour but when the gulf war kicked off they painted them quick over the camo. You can see it on various pics where the paint has worn off or chipped along the leading edges.
Chris Yes Chris, the camo was overpainted in haste with Desert Pink which can be seen in the below pic particularly on fin..though not all had the 'rush job' camo overpaint.
 All looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi looking good, enjoying following your build.cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Nicely done Chris, I just used the grey under mine.
Great painting job!Greetings, Walter
The camouflage paint job is looking really good Chris! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Thanks guys for looking in and comments. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Hi Guys,
Have started on butchering the wings now. I removed the flaps and spoiler from the starboard wing. Then bent and test fitted the flap housing.
I have also painted the ordnance ready for the decals.
Chris magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Coming along nicely Chris, the p.e will add some superb detail.
All that pe, this is going to look very nice. Great work Chris. Mark Regards Markwarren (Mark) Admin
Tonight guys I soldered the flap housing together which was my first time soldering and went quite well. Then I installed the flap housing and glued the wing halfs together. Then I fitted the spoilers to the wing.
Very nice work Chris, soldering p.e is not for the faint hearted.
 Looking fantastic Chris. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
