51 Pages «<3738394041>»
DaDokta`s Build Options
#761 Posted : 11 December 2018 00:29:39
Very nicely done.
Cool Cool Cool
DaDokta
#762 Posted : 11 December 2018 09:44:18
Thanks for your nice comments, guys!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
DaDokta
#763 Posted : 28 December 2018 09:30:56
Just a small update:
I finished the last two yards for the spritsails as well as the boomkins.
Also i added footropes to the jibboom and flying jibboom.
So i finally achieved my goal to complete all the partwork until the end of this year - and i`ll be able to start the new one with the rigging.
Happy new year to everybody!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#764 Posted : 28 December 2018 09:51:00
BigGrin Lovely work Walter Cool and a happy new year Cool
Martyn
#765 Posted : 28 December 2018 11:02:06
BigGrin Nicely done and hope the goggle eyes dont affect you too much when doing the riggingCool
z8000783
#766 Posted : 28 December 2018 11:05:00
Groups: Unapproved
Looking forward to seeing this continue, Walter. Happy new year to you also.
#767 Posted : 28 December 2018 11:20:35
May be a small update but a very nice one at that Walter.... Rigging, now the fun begins....BigGrin BigGrin
#768 Posted : 28 December 2018 12:52:36
Nicely done WalterBigGrin look forward to seeing your progress in the new year with the rigging.
DaDokta
#769 Posted : 09 January 2019 12:13:59
Thanks for your nice comments!
In the meantime i added all the Pendants (also the topmast ones).
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#770 Posted : 09 January 2019 12:21:01
Then i attached the shrouds to the foremast - but when experimenting with how to add the deadeyes - the mast kept turning around.
So i decided to secure the masts to the hull a little bit earlier than suggested in the instructions.
This way i think i could achieve a straight alignment and upright Position of all the masts easier than after attaching all the shrouds
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#771 Posted : 09 January 2019 12:23:03
As a little extra detail i added another mast socket to the mizzen mast at the quarter deck level (was quite fiddly to get it in the right position).
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#772 Posted : 09 January 2019 13:55:57
Looking very good Walter.Cool BigGrin
DaDokta
#773 Posted : 01 February 2019 13:59:24
Thanks Ian!
This is just so you guys don`t think i`m lazy. But although i spent many hours with my Vic one can´t see much progress!
So here are some pics of my shrouds with all the attached deadeyes.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
Garth
#774 Posted : 04 February 2019 13:36:28
Hi Walter,
Looking good. Glad to see some pics.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
#775 Posted : 04 February 2019 14:10:38
Looking great Walter, very soon you'll be onto the dreaded ratlines.....Drool Drool
DaDokta
#776 Posted : 05 February 2019 14:34:15
Thanks Garth , Alan!
Next step was adding the deadeyes to the masttops.
But here i had a problem - as when applying Tension the deadeyes tended to turn and go between the little steps we built on the masttops.
So i came up with this solution:
I added a little wood strip and drilled the holes for the shrouds.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#777 Posted : 05 February 2019 14:36:56
Now i could thread all the shrouds through those new holes and through the ones we previously drilled into the masttops.
This assured that all the deadeyes are now sitting firmly at the same height and direction.
Maybe this helps if anyone has a similar problem.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#778 Posted : 27 February 2019 14:03:49
Hi guys!
I finally attached all the shrouds (including the topgallant shrouds) to the three masts.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
DaDokta
#779 Posted : 27 February 2019 14:08:08
Before moving on i added a few blocks to some of the the eyebolts on the deck, as i want to add lashings to the stays instead of just binding them to the bolts.
I think i will now start producing all the gunport-lids - which i`m not looking forward to!!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#780 Posted : 27 February 2019 17:15:44
Progress is progress Walter and good to see you're moving forward... All looks great....Drool Drool
Alam
This page was generated in 6.408 seconds.
