Thank you for all the comments and support.
I have now applied the decals. I gloss varnished the areas first before applying them, useing fixing decal fluid and then matt varnished the whole model to seal in the paint and decals before using any oils. Once the varnish had a couple of days to dry, I then added some Mig oils, Navy blue and UN white, to give some texture to the grey paintwork. I applied turps with a brush and dotted the oils over the paintwork and with a dry soft brush brushed off in a downward motion until I was happy with the effect. This was allowed to dry for at least 24 hours. Markwarren attached the following image(s): Regards Markwarren (Mark) Admin
Once the oils had dried, I then used the same method and applied some dark rust and dark mud oils, again brushing off in a downward motion. In some areas I did not brush off the rust as much to give a more heavily rusting effect. This will now be left to dry for a week before the detailed weathering can be applied, giving me time to finish off the machine guns and start with the Navy soldiers.
More soonMarkwarren attached the following image(s): Regards Markwarren (Mark) Admin
Hi Mark, Look's like 100 pairs of troops size tens have walked over your landing craft and with the Oil's and paint work this will turn out a very serious build in the competition. Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
coming along a treat, weathering is spot on.
Hi looking great weathering is fantastic,never tried oils me self ,have to have try one day ,cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Thank you guys for looking in and your comments. mogwai wrote:Hi looking great weathering is fantastic,never tried oils me self ,have to have try one day ,cheers mick. The oils are Fairly easy to use and are easily wiped off if you make a mistake, but they do need to be sealed with a varnish when dry. Mark Regards Markwarren (Mark) Admin
Thanks Ian, still might put a couple of the troops in there smoking. Mark Regards Markwarren (Mark) Admin
A little more done on the landing craft. I have attached the front ramp. Unfortunately, I had to take off the closing hooks as they did not attach to the closure very well when fitting. I have also metalized the steel rope, which will also have some grease added later in the build. I have finished the second machine gun with the PE and attached the shield to both. These were then primed. As you can see, couldn’t help but to dry fit them to see how they look. The PE kit also comes with the ammunition boxes that fit to the side of the machine guns, along with the bullet belts.
More soon
 Nicely done Mark and looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi Mark fantastic work on the machine guns and ammo boxes. As for your figures theirs always some one who disobeys the rules look forward to seeing what you do with them. How many figures have you got to go in the landing craft. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Thank you for you comments and looking in ian smith wrote: How many figures have you got to go in the landing craft. Hi Ian, there are 3 crew and 25 infantry. Cheers Mark Regards Markwarren (Mark) Admin
Lovely bit of weathering there Mark!  Very nice! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Thank you for your kind words and support guys, very much appreciated. Mark Regards Markwarren (Mark) Admin
I have started weathering the hull. A lot of experimental work for me on this model trying to get it to look as realistic as possible. Just done the one side at the moment, wanted it to be a very worn look.
Thanks for looking, more soon.
MarkMarkwarren attached the following image(s): Regards Markwarren (Mark) Admin
Stunning work as usual Mark, simply looks amazing..... Regards Alan
 All looking good and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Superb work as always Mark, the weathering looks fantastic.
