Looks like a lot of work to get the outside shape, but will be worth the effort. WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Your right there Derek about the work,the main thing with this was to try and keep the same curve all round,and that can only be achieved by sanding down to a knife edge and continuous checking.Thanks for turning the pages. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
A lovely clean job Trev  nice work. Al
Thanks for looking Al, had a problem when assembling the length beams when cutting clefts on the two suspension stabilizers, I slipped and ran off chipping the wood,so I have had to scratch build three more to match. Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Looking great, lot of work going into this Ken's the name modeling's the game.
Hi Ken, Good to see you looking in thank you more soon Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Trev. looking fantastic very nice work. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Hi Kev, Thanks for looking in,added skins to the build, glued them as close as possible which will help with the final finish more soon. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi all, Just a quick update on progress I have finished fitting 1x5mm outer beams and shaping, also removing the sharp edges this will give a bulging effect ready for the dark outer wood more soon.  Thanks for looking Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
A lovely job as always Trev and I love the neatness you are showing in your work, well done.
Kev  Per Ardua Ad Astra
Great job Trev  looks spot on. Al
Looks great so far. Ken's the name modeling's the game.
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,271 Points: 22,120 Location: Northamptonshire, England
That’s lovely work Trev.  Mark Regards Markwarren (Mark) Admin
Hi Guy's, Thank you for looking in. @ Kev Sometimes I get so involved it becomes hard to keep neat and tidy. @ Spal Moving on now not only with coach work but also with the suspension. @ Ken looking forward to building the outer wood which will be a high polish. @ Mark this build is so well thought out that I have a job to stop building it's so different. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
update:17.3.19 With the dark wood 1.5 mm I have added back and front following the fitting order as shown in my photo above,then to sand down with a fine grain sand paper until the surface is smooth and uniform. Then cut pieces from 0.6x30 sheet to line the exterior part of the curved wall, I used a brush to spread the glue over the entire walls, once the glue had dried I cut away all the surplus edges and sanded down leaving entire surface smooth and even,having reached this point I intend to polish the wood.  Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Wow that`s looking real good already. When you`ve given it the full treatment it will be superb. Keep it up. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Hi Derek, have started the polishing but very time consuming and you need a lot of patience. Regards Trev Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
That is really looking excellent Trev, great work. Mark Regards Markwarren (Mark) Admin
Looking really impressive, all you're hard work is paying off.... Regards Alan
