Poor door fit Options
alemo
#1 Posted : 18 February 2019 16:47:57
First let me say I know it's a model but I have seen many years ago better door fit on dinky toys.
The nearside door opens and closes without problems, a bit sloppy but never mind.
The off side door is difficult to open and close because it jams on the striker plate.
I have stripped the door down and removed the paint from the hinge bar and it's contact point in the door to ease the door forward as much as possible. This has given some improvement but still not good enough.
I am reluctant to file off the striker plate as doing that will leave bare metal although on a full size vehicle they aren't
painted anyway.
The doors appear to be the correct size in relation to the body
Any ideas? Anyone else had the same problem?
Alec
alemo attached the following image(s):
Adapt, improvise, overcome.
#2 Posted : 18 February 2019 16:58:41
That's new one on me.
Mine went together fine. I don't know of anyone with this problem but you never know.
Could it be that you have a slightly dodgy door part?
I'm sure you could get a replacement from CS...
Roy.
alemo
#3 Posted : 18 February 2019 17:19:58
Thanks Roy,
Three possible dodgy parts, The door? The hinge? or The body?
Looks like I try packs 6 and 7 first and go from there.
Alec
#4 Posted : 18 February 2019 19:34:59
Like Roy I also had no issues with the doors nor have I heard of anyone else having the same issue.
alemo
#5 Posted : 07 March 2019 16:05:03
c/s supplied replacement issues 6 & 7 which fit ok so problem solved.
Alec
#6 Posted : 07 March 2019 18:26:12
Alec
Glad to hear you got it sorted and are now back on trackBigGrin
Blue1905
#7 Posted : 31 March 2019 08:11:57
Rank: Newbie
Just for the record, you're not the only one.
Fitted n/s door yesterday, and the fit is awful. I'm assuming it's the door shape that's out and not the body shell.
alemo
#8 Posted : 31 March 2019 10:55:35
That's horrible, get customer services to send replacement door and hinge issues 6 and 7.
Alec
#9 Posted : 31 March 2019 16:30:05
C/S are really good at sending out replacement parts.
I didn't have any issues with my doors but I gather a few people have.
It will get sorted if you ask.
This page was generated in 0.588 seconds.
