Painting guide or diary with good painting process steps? Options
x_dfo
#1 Posted : 19 February 2019 23:32:42
Rank: Advanced Member
Hi,
I'm nearing issue 90 and I haven't done much painting due to being unclear as to how to avoid major complications (including needing to use filler) when painting to completion before the final hull assembly.
Is there a specific build diary or guide that helps clarify where to assemble before painting or vice versa?
Cheers,
D
#2 Posted : 19 February 2019 23:45:36
BigGrin Mark did a customized build on the forum take a look here-
https://forum.model-spac...aspx?g=topics&f=315
Steve Dymszo also did a painting guide online in 3 parts-
https://forum.model-spac...spx?g=posts&t=16940
and if you search YouTube there are several more out there to look atCool
x_dfo
#3 Posted : 19 February 2019 23:58:58
Thanks!
This page was generated in 0.129 seconds.
