R2D2 dosnt seem right Options
Maty87
#1 Posted : 22 February 2019 09:45:57
finally got the spare sensors for the legs tested ok but R2 still seems to crash into objects anyone else have this is it working as it should or is there something wrong with it also I'm sure if you pick him up he should stop moving as if he went over a step so he didn't fall and brake?
any info or help will be much appreciated
#2 Posted : 22 February 2019 10:23:30
Hi
In what mode is he bumping into things.
Maty87
#3 Posted : 22 February 2019 10:40:18
patrol mode and when hes on and decides to move forwards
#4 Posted : 22 February 2019 15:11:18
This is being investigated by the developers.
Maty87
#5 Posted : 22 February 2019 17:43:22
Ok thanks say i had 2 new sensors in the leg that was originally working backwards these new ones worked correct well seemed to they seemed slightly slow at responding is there away i can upload a video so this can be seen
#6 Posted : 22 February 2019 20:43:51
If you want to upload a video, then use YouTube and post the link here.
Maty87
#7 Posted : 24 February 2019 22:48:08
here are the links hope this works and helps
https://youtu.be/E5QuRRAVPEQ
https://youtu.be/SX2YwMQ4g1c
#8 Posted : 25 February 2019 08:59:11
Hi
Your first video shows you operation him manually. The sensors do not work in manual mode. The ultrasound sensors in both left and right shoulders have an effective range which means you wouldn’t be able to move R2 in any tight space if they were to remain active.
Your second video, I’m assuming is in patrol mode, the space you re moving him in is very tight. You can see him moving away from certain object, however whilst he is moving he then comes up against another object, ie, the basket, and because he is tight up against it the effective range now cannot see it to move away from it.
If you can try in a larger area or less objects that are close together.
Maty87
#9 Posted : 25 February 2019 10:22:16
Ok will try that thanks i did asume that in manual mode
Maty87
#10 Posted : 25 February 2019 23:35:30
This seems much better so all seems giod now i believe
https://youtu.be/ECDVfX_2gqQ
#11 Posted : 25 February 2019 23:46:25
Great glad you’ve got it sorted, seems much better now.
Maty87
#12 Posted : 25 February 2019 23:59:42
Yes it does thanks for the help just need to get new foot housing as one of the screw tubes snapped
This page was generated in 2.668 seconds.
