R2D2 head back to front Options
jevypaul
#1 Posted : 22 February 2019 22:59:22
Rank: Beginner Level 1
help...
I have just completed my R2D2 and when i power it up it does jerk forward which is correct and it moves head left and right which is correct. However the head then situates itself basically back to front? how can I rectify this please
#2 Posted : 23 February 2019 00:10:46
Hi , can you check you have your limit switches the right way round there the ones attached to the top of the body ring.
jevypaul
#3 Posted : 23 February 2019 12:36:00
hi where do i find them and what issue would it have been
#4 Posted : 23 February 2019 12:58:02
Issue 83 They are clearly marked 'L' and 'R' you may have them the wrong way round.
jevypaul
#5 Posted : 23 February 2019 13:58:31
hi I have swapped left head sensors and right head sensors and head always remains back to front?!? so frustrating.
I cant even connect via app and it constantly goes in patrol mode but again head always ends back to front
I cannot coonect via app as camera doesnt scan at all in dact it does do anything
please help
#6 Posted : 23 February 2019 14:06:55
You will next need to check that all your conectors are labeled correctly and pluged into the correct sockets.
With the camera have you attached the ribbon cable to the board correctly and again is it the correct way up when inserted.
jevypaul
#7 Posted : 23 February 2019 16:34:27
yes I have them connected the exact same position as in diagram. It still has head the wrong way around after powered up
jevypaul
#8 Posted : 23 February 2019 16:37:50
thanks for advice I will attempt to take it all apart to get to all connections and will advise if all correct.
Is there an easy way of dismantling or is it wise to take apart working backwards from issue 100. Also before doing that should I dissconnect batteries
#9 Posted : 23 February 2019 17:18:30
I would disconect the battery box from the MCU unit before attempting any checkd on the conections. Just take the sides and dome off your R2 to get access to the conections.
jevypaul
#10 Posted : 24 February 2019 09:59:53
thanks I will give that a go and may be bext weekend . i will repost
This page was generated in 0.197 seconds.
