Cheers guys, for your nice comments.
I have now installed all the flaps, slats and spoilers on one wing. Now onto the second wing.
Chrismagpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,389 Points: 22,474 Location: Northamptonshire, England
They look awesome, what a difference they make. Mark Regards Markwarren (Mark) Admin
Very nice Chris, they look amazing!
Now that is an enhancement, truly looks superb.... Regards Alan
Superb work Chris  they look fab. Al
Thank you guys for all your nice comments.
Only a small update, I have primed one wing ready for the camo coat, and I've got halfway through . the second wing with the flaps being made and the housing fitted.
Chris magpie1832 attached the following image(s): On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
All looking great Chris, loving the detail..... Regards Alan
 All looking good and nicely done Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Rank: Pro  Groups: Registered
Joined: 23/12/2018 Posts: 318 Points: 949 Location: Illinois, USA
Beautiful. Mark Currently: Soliel Royal, Deag DC-3, DeAg Ford Shelby Mustang GT 500
Under the Bench:
The flaps look awesome!Greetings, Walter
 Nice work Chris
Nice progress Chris. coming along a treat! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Thanks guys for looking in and your comments.
I Have installed the flaps on the other wing now, then I gave a coat of primer. I then installed the pylons into their position.
I have installed a brass rod onto the rear fuselage for the rear wings as the plastic fixings are not too strong, also this way I can remove them as with the main wings they are fully removable so can be painted then installed.
Chris
 All looking good and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Another very nice update Chris, all looking fab.... Regards Alan
Nice idea with the cutouts to mount the wings Chris  I have used the brass rod for the tailerons on previous Tonka builds Al
Thanks guys for looking in and commenting. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Another little update on the Build.
I have given the wings a coat of camo. They will be getting a thin coat of Desert pink later today. I've also primed the metal undercarriage built the rear legs then painted and weather them.
Here is coat one of the desert pink with pre shade done with pink and a darker matt brown. Should get its top coat later.
Chris
