16 Pages 123>»
Hachette 1:200 Battleship Bismarck re-release Options
CaptnBirdseye
#1 Posted : 25 February 2019 14:03:30
Rank: Superelite
Hi guys,
I've had my eye on a 1:200 scale Bismarck kit for a while now. In fact that was what i was originally looking for when i stumbled on my U96 kit (too good a price to miss). Originally, i wanted the Amati kit through Modelspace, which is reputed to be the most accurate:
https://www.model-space....-bismarck-full-kit.html
Now these haven't been available for some time now, and i doubt the kit will be re-released (never say never as i know a few builders who would sign up for that one if they ever did!). So a week or so back, when i saw Hachette were re-releasing their partwork 'Build the Battleship Bismarck', i decided i wanted to give it a try. BigGrin
http://www.battleshipbis...0Tt6n0jw5IaAmiXEALw_wcB
Now, i am going to enter into this build with an open mind, unbiased and with no preconceptions. Having said that, the opinions stated will be mine, and mine alone. I appreciate that this re-release is significantly different from the original release, namely metal hull and plastic decking. But i am interested enough in the kit to give it a go.
BigGrin The first two issues have arrived today, and i will be starting the build later, with a review of what i've received so far and build log.
Here's to a happy build ThumpUp
Gray
#2 Posted : 25 February 2019 15:56:52
Good luck with the build, look forward to seeing how she turns out....Cool Cool
CaptnBirdseye
#3 Posted : 25 February 2019 20:58:51
Rank: Superelite
BigGrin Thank you Alan, so do i Laugh
Ok, so first impressions. Comes well packaged, with issues 1 & 2 in in separate polythene bags. You also get a free A4-sized cutting mat (handy for cutting the plastic around the parts BigGrin). The magazine looks well laid out, with images on the left-hand side of the page and relevant build text next to it on the right.
The middle pages give tips on modellers workshop, although i would think most subscribers would have most, if not all, of the tools required. The later pages cover the history & destiny of the ship. So, overall, a reasonable first impression of the magazine and packaging.
The photos show the details of Issue 1. I won't do this for future issues, but just wanted to show what you can look forward to each issue.
Shauncnh
#4 Posted : 25 February 2019 21:10:00
Looking good, I subscribed on Saturday so hopefully have my first issue in the next week or so.
Regards shaun
Building-RC spitfire
CaptnBirdseye
#5 Posted : 25 February 2019 21:15:04
Rank: Superelite
BigGrin Hi Shaun, thanks for looking in and your comments ThumpUp
If you ordered on-line, you should get your first issue in under a week, i know i did BigGrin
First Tip: When opening the packaging of Issue 1, be very, very careful, as two of the parts are very small and very easy to loose!
Gray
#6 Posted : 25 February 2019 21:26:11
Good to see you doing a build on this Gray, i'm sure you will do a great job on her.
CaptnBirdseye
#7 Posted : 25 February 2019 21:56:21
Rank: Superelite
BigGrin Thanks Al, appreciate the support ThumpUp
CaptnBirdseye
#8 Posted : 25 February 2019 22:00:01
Rank: Superelite
Issue 1:
Contents:Forward deck section, Warping winch base plate, 2x Capstan drums, Capstan head, Capstan head lower part, 2x Housings, Hull Bow section, 6x Bollards, Small Hatch, Large Hatch.
Firstly, glue the two capstan drums to the warping winch. I glued from underneath to make sure no overspill. Next, glue the two halves of the capstan head and store safely for future use.
Apply glue to the underside of the warping winch and seat it in the large recess in the upper deck. Glue the two housings into the rectangular holes astern on the upper deck with the openings facing the rear of the deck. The six bollards are glued to the uper deck in their respective holes. I had fo use a round file on one of the holes so the bollard seats properly, but that was the first piece of cleaning up i had to do.
Finally for this stage, i fitted the two hatches in their respective places, aligning the hinges.
Along with the metal bow section of the hull, this completes this stage.
#9 Posted : 25 February 2019 22:04:49
Hi look forward to following your diary for this,my first parts came today,but I'm in 2 minds whether to do diary or not yet.cheers mick.BigGrin
CaptnBirdseye
#10 Posted : 25 February 2019 22:14:59
Rank: Superelite
BigGrin Hi Mick, thanks for looking in. Glad yours came today too. I hope you will do a diary, as i would definitely follow your build too ThumpUp
Gray
#11 Posted : 26 February 2019 02:37:25
following this with interest.That deck looks pretty good considering its plastic
#12 Posted : 26 February 2019 05:13:53
BigGrin Nice start and looking goodCool
#13 Posted : 26 February 2019 08:51:28
Nice start Gray.ThumpUp
CaptnBirdseye
#14 Posted : 26 February 2019 09:50:14
Rank: Superelite
BigGrin Carl, Andy, Mark - thanks for looking in and your comments.
You're right Carl, the deck detail does look good so far ThumpUp
Gray
#15 Posted : 26 February 2019 10:35:14
Good to see you up and running Gray, looking good....Cool Cool
CaptnBirdseye
#16 Posted : 26 February 2019 10:44:59
Rank: Superelite
BigGrin Thanks Alan, more to follow ThumpUp
#17 Posted : 26 February 2019 15:31:04
Hi looking good so far, nice to put together must admit. Cheers mick BigGrin
CaptnBirdseye
#18 Posted : 26 February 2019 16:37:13
Rank: Superelite
BigGrin Agreed Mick, but that's just how we want it, right?
#19 Posted : 26 February 2019 18:00:17
Nice one Gray will be following this oneBigGrin i built the previous one released years agoBigGrin regards PhilCool
CaptnBirdseye
#20 Posted : 26 February 2019 18:06:45
Rank: Superelite
Hi Phil, thanks for looking in. Which one did you build, Hachette or Amati?
Cheers
Gray
16 Pages 123>»
This page was generated in 0.438 seconds.
