Hi guys, I've had my eye on a 1:200 scale Bismarck kit for a while now. In fact that was what i was originally looking for when i stumbled on my U96 kit (too good a price to miss). Originally, i wanted the Amati kit through Modelspace, which is reputed to be the most accurate: https://www.model-space....-bismarck-full-kit.html
Now these haven't been available for some time now, and i doubt the kit will be re-released (never say never as i know a few builders who would sign up for that one if they ever did!). So a week or so back, when i saw Hachette were re-releasing their partwork 'Build the Battleship Bismarck', i decided i wanted to give it a try. http://www.battleshipbis...0Tt6n0jw5IaAmiXEALw_wcB
Now, i am going to enter into this build with an open mind, unbiased and with no preconceptions. Having said that, the opinions stated will be mine, and mine alone. I appreciate that this re-release is significantly different from the original release, namely metal hull and plastic decking. But i am interested enough in the kit to give it a go.  The first two issues have arrived today, and i will be starting the build later, with a review of what i've received so far and build log. Here's to a happy build Regards Gray
Good luck with the build, look forward to seeing how she turns out.... Regards Alan
 Thank you Alan, so do i Ok, so first impressions. Comes well packaged, with issues 1 & 2 in in separate polythene bags. You also get a free A4-sized cutting mat (handy for cutting the plastic around the parts  ). The magazine looks well laid out, with images on the left-hand side of the page and relevant build text next to it on the right. The middle pages give tips on modellers workshop, although i would think most subscribers would have most, if not all, of the tools required. The later pages cover the history & destiny of the ship. So, overall, a reasonable first impression of the magazine and packaging. The photos show the details of Issue 1. I won't do this for future issues, but just wanted to show what you can look forward to each issue. CaptnBirdseye attached the following image(s):
Joined: 08/02/2015 Posts: 274 Points: 812 Location: Malmesbury
Looking good, I subscribed on Saturday so hopefully have my first issue in the next week or so. Regards shaun Building-RC spitfire Build- titanic,Skyrider drone, solar system, T72 tank
 Hi Shaun, thanks for looking in and your comments If you ordered on-line, you should get your first issue in under a week, i know i did First Tip: When opening the packaging of Issue 1, be very, very careful, as two of the parts are very small and very easy to loose! Regards Gray
Good to see you doing a build on this Gray, i'm sure you will do a great job on her.
 Thanks Al, appreciate the support
Issue 1: Contents:Forward deck section, Warping winch base plate, 2x Capstan drums, Capstan head, Capstan head lower part, 2x Housings, Hull Bow section, 6x Bollards, Small Hatch, Large Hatch. Firstly, glue the two capstan drums to the warping winch. I glued from underneath to make sure no overspill. Next, glue the two halves of the capstan head and store safely for future use. Apply glue to the underside of the warping winch and seat it in the large recess in the upper deck. Glue the two housings into the rectangular holes astern on the upper deck with the openings facing the rear of the deck. The six bollards are glued to the uper deck in their respective holes. I had fo use a round file on one of the holes so the bollard seats properly, but that was the first piece of cleaning up i had to do. Finally for this stage, i fitted the two hatches in their respective places, aligning the hinges. Along with the metal bow section of the hull, this completes this stage. CaptnBirdseye attached the following image(s):
Hi look forward to following your diary for this,my first parts came today,but I'm in 2 minds whether to do diary or not yet.cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
 Hi Mick, thanks for looking in. Glad yours came today too. I hope you will do a diary, as i would definitely follow your build too Regards Gray
following this with interest.That deck looks pretty good considering its plastic
 Nice start and looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice start Gray. Regards Markwarren (Mark) Admin
 Carl, Andy, Mark - thanks for looking in and your comments. You're right Carl, the deck detail does look good so far Regards Gray
Good to see you up and running Gray, looking good.... Regards Alan
 Thanks Alan, more to follow
Hi looking good so far, nice to put together must admit. Cheers mick Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
 Agreed Mick, but that's just how we want it, right?
Nice one Gray will be following this one  i built the previous one released years ago  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Hi Phil, thanks for looking in. Which one did you build, Hachette or Amati?
Cheers Gray
