Star Wars, Sci-Fi and Space
R2-D2
R2-D2 Discussion Forum
Red light on front not working and lightsaber stuck up?
Joined: 25/02/2019 Posts: 2 Points: 6 Location: Doncaster
So everything else seems to have gone well with my R2-D2 build, however the front light doesn't turn on and the lightsaber pushes up when I choose that option, but never goes back down. I'm guessing the light connections could be wrong but why would the lightsaber not go back down? It's just stuck there and I can't push it down either. I probably could with force but that's risking breakage.
Check all the cables are in the right slots and pushed in firmly. Regards Mark Regards Markwarren (Mark) Admin
After a check in the dome, I saw that the red light connection wasn't in properly, that now works. However the lightsaber connection was right, and it still doesn't work at all. I opened up the section where the motor is and the motor just doesn't turn at all anymore. I guess the motor is broken and I need another?
Joined: 12/01/2017 Posts: 572 Points: 1,731 Location: Cambridgeshire
As it worked the first time going up, the first step should be to check the lead from the sensors, and the sensors themselves. If the sensors are the wrong way round, it could be that if you are trying to get it down, the sensors think it is already there. Current Builds Eaglemoss: Ecto-1, BTTF Delorean [Installing Mods] Hachette: T800 Endoskeleton Agora Models Shelby Cobra 427 [Plate 031] BanDai 1:5000 Imperial Star Destroyer AMT 1991 U.S.S. Enterprise Bridge [Installing Mods & Lights]
Finished Builds Deagostini: R2-D2 [Never getting batteries]
R2-D2
