R2D2 battery box Options
Ron
#1 Posted : 26 February 2019 17:11:35
Rank: Amateur Level 1
Has anyone found that by using a multimeter across the + red and- black lead from the battery box that it actually does something to the box circuitry, my box gave 12.5 volts for about 5 secs then nothing, got a replacement box and the same thing happened 12.5 volts for about 5 secs then nothing, would the multimeter actually
damage the circuit in the box, i am a electrician so do know how to use a multimeter
#2 Posted : 26 February 2019 19:21:06
A multimeter uses very low current and very high impedance designs to minimise this possibility. Lots of people have tested the box using such and without problem.
This page was generated in 0.630 seconds.
