80 Pages «<3536373839>»
Sticky Wickett
#721 Posted : 28 February 2019 23:04:37
Both completed canisters in their correct locations on the conning tower upper deck. They are not glued in place at this stage as i will paint and weather them separately. It also makes it easier to paint the conning tower with less details in the way.
Sticky Wickett
#722 Posted : 28 February 2019 23:07:14
Well that's it for this week. Next week i will start detailing the 3.7cm gun for the lower deck.
Thanks for looking in, have a great weekend and happy modelling.BigGrin
Phil W.
#723 Posted : 28 February 2019 23:18:41
Impressive display of scratch building, they look amazing.....Drool Drool
#724 Posted : 28 February 2019 23:19:20
Great work as usual Phil.Love Drool
#725 Posted : 01 March 2019 11:50:10
I have just been catching up with your build and I have to say more masterful work as ever. Always a pleasure to see your progress.
Sticky Wickett
#726 Posted : 01 March 2019 12:26:56
Thank you Alan!BigGrin They were very fiddly to make with the odd bit flying off into the kitchen never to been seen again.BlushingAlso, lots of trial and error, but I'm very happy with the end result.
Phil W.
Sticky Wickett
#727 Posted : 01 March 2019 12:27:58
Thank you very much Mark!BigGrin
Phil W.
Sticky Wickett
#728 Posted : 01 March 2019 12:31:31
Thank you very much Graeme!Cool I'm glad you're enjoying the build.
Phil W.
kpnuts
#729 Posted : 01 March 2019 19:32:32
You really are going all out on this one, really incredible work load (how big is this, it must be huge) loving your dedication.
#730 Posted : 01 March 2019 20:38:39
There should be an award for the most patient and diligent build diary because this one would win it hands down.great work as always
#731 Posted : 01 March 2019 23:35:46
Nicely done as always PhilBigGrin
Sticky Wickett
#732 Posted : 06 March 2019 13:15:59
Thanks very much Ken!Cool The U-boat measures 1.4 meters [4 feet] in length, so pretty big. Lots of scope for fine scale detailing in this scale [1/48] and on such a large model, it takes awhile.
Phil W.
Sticky Wickett
#733 Posted : 06 March 2019 13:20:29
Thank you very much Carl! It certainly takes a lot of patience, but I love adding all the small details!
Phil W.
Sticky Wickett
#734 Posted : 06 March 2019 13:21:50
Thank you very much Al!Cool
Phil W.
kpnuts
#735 Posted : 07 March 2019 07:23:58
As always great work going on here
Sticky Wickett
#736 Posted : 08 March 2019 00:05:48
Thankyou Ken!
Phil W.
Sticky Wickett
#737 Posted : 08 March 2019 00:12:17
This weeks update sees the start of detailing and modifying the Flak 37 gun that will be located on the lower deck of the conning tower.
The gun is complete as it stands, but being a 3d printed affair, it lacks strength and is very fragile. Some of the finer details were also obscured, so i decided to make the gun more robust and replace any details with scratch built items.
The first job was to split the gun into several sections by carefully cutting with a razor saw.
The attached photo shows the shield removed from the gun in three pieces.
Sticky Wickett
#738 Posted : 08 March 2019 00:16:27
The gun was printed in a fixed position, however, i wanted to position it at a different angle. For this I drilled through the supports and through the gun itself to provide a locating hole.
The attached photo shows the 1.0mm diameter drill ready.
Sticky Wickett
#739 Posted : 08 March 2019 00:16:55
Drilling in progress.
Sticky Wickett
#740 Posted : 08 March 2019 00:19:20
When the drilling was complete, i then cut the gun away from its supports with a razor saw.
The attached photo shows the gun separated and the aftermarket brass barrel i mentioned in a previous post alongside it.
Guest (16)
This page was generated in 4.716 seconds.
