3 Pages <123>
D-Day Operation "Overlord" Options
#21 Posted : 05 January 2019 00:11:09
Wow, you’ve got your work cut out there Derek. Great kit.
You might want to try the flickering LED,s, different from flashing. I used them in the Podracer dio for the engine. Very effective and could work with what you are doing.
#22 Posted : 05 January 2019 00:31:22
Thanks Mark Cool
I have flickering leds on order and was going to experiment connecting one to two consecutive pulses from the IC outputs to work a flickering led for longer as I will have spare outputs.
The good thing is that I can fit the electrics late in the build so have plenty of time to experiment and I have purchased a breadboard for testing so its a case of plugging components in/out rather than soldering.
#23 Posted : 05 January 2019 08:51:55
BigGrin Great stuff its here and have fun with the buildCool
Kev the Modeller
#24 Posted : 05 January 2019 18:10:32
Glad that your items have arrived Derek, looks like quite a well thought out and comprehensive diorama that you have there with a lot of individual kits in one box. Should build into a fab diorama especially with all of the flash/bang electronics that your going to install!
Good luck with the build, looking forward to following your diary. ThumpUp
Per Ardua Ad Astra
#25 Posted : 26 February 2019 22:14:58
Now update time for this one and all has not been good news since the last post.
Crying Crying Crying
When I opened the sealed kit originally I made the assumption that everything would be present and correct. Must stop making assumptions. Angry
I have primed the dio base and will put base colours on prior to adding sea colours, real sand and grass. To that end I have purchased basing sand and flock grass (OO gauge railway scenic materials). I have also started the basic construction of the gun emplacement that needed lots of flash removing before the interlocking parts would fit.
It was when I primed the Sherman tank that I noticed a gap on the sprue where a hatch should be. Like I said when I purchased the full kit it was all sealed in its individual bags. Not till I opened the Sherman bag did I realise there was a part missing, so went to ebay and picked up a replacement kit.
As you can see in the last pic I now have a Sherman kit to replace a tiny hatch.
Hey Ho, these things happen. LOL
#26 Posted : 26 February 2019 23:35:45
Hi coming on well ,look forward to more ,cheers mick.BigGrin
Kev the Modeller
#27 Posted : 03 March 2019 21:58:22
Glad you managed to source the missing hatch Derek, though not the cheapest fix, you must have been quite annoyed? Looking forward to seeing the scene unfold as the build progresses. ThumpUp
Per Ardua Ad Astra
#28 Posted : 04 March 2019 06:29:40
BigGrin All looking good and lots of goodys thereCool
#29 Posted : 04 March 2019 08:33:32
Nice one Derek, glad you got a replacement. You’ve certainly got your work cut out with that scenery.Cool
#30 Posted : 04 March 2019 11:31:01
Looking good Derek.
Trev.
#31 Posted : 04 March 2019 15:40:46
Good work there Derek!Cool Are the two hatches identical? If you haven't tried it before I can strongly recommend getting a small 'starter kit' of silicone rubber and acrylic resin - for a few pence you could make a mould from the hatch you had and cast a resin one for the one that was missing! Too late now but it saves pounds for the future!BigGrin
Best of luck!
#32 Posted : 07 March 2019 12:58:02
Many thanks for all the comments and tips, much appreciated.Cool
Update on the scenery:
Have applied the initial colours to the base and added the beach sand.
Also painted the main section of the gun emplacement and added the flock grass around the base.
That`s all for now. BigGrin
#33 Posted : 08 March 2019 09:04:38
Nice work Derek, coming on very nicely.Drool
#34 Posted : 09 March 2019 12:25:16
Looking good Derek. Doing a good job on the diorama.
Chris
#35 Posted : 09 March 2019 18:31:00
Hi Derek,coming along very well, and with the sand effect and waves will look very affect.
Trev
#36 Posted : 09 March 2019 23:58:52
Looking good Derek, making very nice progress....Cool Cool
Sticky Wickett
#37 Posted : 13 March 2019 11:27:18
Looking really good Derek. The sand and grass make all the difference!Love
Phil W.
#38 Posted : 13 March 2019 15:22:30
Thanks to all who looked in and for the nice comments. Cool Cool
Small update on the LCM landing craft while I`m on with fitting the gun emplacement to the dio base and blending them into each other.
The main assembly of the craft went together very well. I then started on the three figures of the crew. One of the crew is stationed inside the cabin area and that`s where some issues arose. The crew member was a perfect fit to the height of the wheel in the cabin, but the windows were above the crewmans head and the side windows were also behind him so he could not actually see through any window. So after a cut and shut job I`ve managed to get the windows in the correct position.
#39 Posted : 13 March 2019 15:51:32
Nice bit of work there Derek got round that one ok.
Trev
#40 Posted : 13 March 2019 16:14:48
Trev
Thanks Trev, BigGrin
Not a hard fix, but me thinks it`s one that should not have been needed.Blink
3 Pages <123>
This page was generated in 0.299 seconds.
