Samba floor carpets Options
andali15
#1 Posted : 11 March 2019 19:10:02
Hi all. Has anybody got to build box 3 as I have placed the floor carpets in position making sure they locate in the holes but find if I turn upside down they fall out. Maybe superglue on corners of underside of rubber mat or will it get pinched tight when the sides of body go on later in build. I know the seating will go in on top and the frames may hold their part of mat. Am I worrying unnecessarily? Andy.
#2 Posted : 11 March 2019 19:26:22
As you progress through the build you will find that the rubber matting is held in place by the seats etc.
If you need to invert the floor of the Samba until you fit the seats then just replace the mats when done.
This page was generated in 0.297 seconds.
