Joined: 07/03/2019 Posts: 5 Points: 15 Location: Keighley, West Yorkshire
R2 D2 only goes round and round when you tap on the move forward button. Luke always appears moving from the projector and Leia doesn't show up. The voice commands don't work. Please help.
Check the sensor conections and are you opperating him in a crowded room,also what floor surface are you running him on. For the projector double check the conections and did the projector work ok when you did the test. Some people have enlarged the hole on the dome reciever and had better results with voice comand you could try that. Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
