80 Pages «<3839404142>»
Sticky Wickett
#781 Posted : 14 March 2019 23:59:50
Above this small component I fitted a lever with a small rivet acting as a pivot rod.
Sticky Wickett
#782 Posted : 15 March 2019 00:01:37
The next small component consists of brass rod and tubing and plastic square strip, all filed to look similar to actual photos.
Sticky Wickett
#783 Posted : 15 March 2019 00:02:42
The attached photo shows this small piece fitted.
Sticky Wickett
#784 Posted : 15 March 2019 00:06:03
Now that all of the details are complete on the gun body it was time to turn my attention to the gun shield. First job was to file off all of the small details, prepare all edges and glue the three sections of the shield together.
I then made two profiled sections and glued these to the shield. These profiled sections will attach to the gun body.
Sticky Wickett
#785 Posted : 15 March 2019 00:10:37
Now begins the addition of all the details to the shield starting with two, small grab handles. Made from 0.5mm diameter brass rod bent to shape then glued into 1.5mm wide x 1.0mm deep plastic strip. The attached photograph highlights their small size.
Sticky Wickett
#786 Posted : 15 March 2019 00:11:35
Grab handles fitted to the gun shield.
#787 Posted : 15 March 2019 00:13:26
Now they are fiddly little guns. Doing a nice job on those. I dread when I start on my Iowa with all the Pontos etch.
Chris Cool
Sticky Wickett
#788 Posted : 15 March 2019 00:13:57
Well that's it for this week and i hope to finish the Flak 37 gun off next week so stay tuned for the final part of these modifications.Cool
Thanks for looking in, have a great weekend and happy modelling!BigGrin
Phil W.
Sticky Wickett
#789 Posted : 15 March 2019 00:19:43
Chris Cool
Thanks Chris.Cool It's trying to hold these small parts I find trickiest, especially when trying to file an edge without filing fingers!LOL Your Iowa build sounds interesting. I look forward to seeing the etch on that, i bet it's miniscule!Blink
Phil W.
#790 Posted : 15 March 2019 09:05:30
Stunning work as usual Phil.Love
Sticky Wickett
#791 Posted : 15 March 2019 13:32:43
Much appreciated. Thank you Mark!BigGrin
Phil W.
#792 Posted : 15 March 2019 22:22:41
Great job Phil not sure my eyes would let me do those grab handlesBigGrin
Garth
#793 Posted : 18 March 2019 12:22:06
Hi Phil,
Such inspiring work on you gun. AwesomeDrool Drool Drool
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
Sticky Wickett
#794 Posted : 19 March 2019 17:39:28
Thank you Al. Yep, a tad fiddly and i often heard a distant 'ting' as a small piece of brass flew across the room!Blink Blushing
Phil W.
Sticky Wickett
#795 Posted : 19 March 2019 17:40:29
Garth wrote:
Hi Phil,
Kind regards,
Garth
Thank you very much Garth. I'm hoping to get it finished this week!Blink
Phil W.
#796 Posted : 19 March 2019 23:25:57
Stunning work once again Phil, very well done....Drool Drool
Sticky Wickett
#797 Posted : 20 March 2019 11:12:10
Thank you very much Alan!BigGrin I'll be posting another update later this week which will hopefully see the conclusion of the Flak 37.
Phil W.
Sticky Wickett
#798 Posted : 22 March 2019 00:09:21
This week I continued with adding details to the Flak 37 gun for the conning tower lower deck.
I turned my attention to the gun shield and started by adding plastic strip and rod to simulate hinges, as the original had the capability of folding its outer edges. I also drilled and inserted to small lengths of 0.8mm diameter brass tube to simulate the locking holes for when the gun shield was folded.
Sticky Wickett
#799 Posted : 22 March 2019 00:11:21
The attached photo shows the tiny locking pins I made from 0.5mm brass rod bent to shape and the ends held together by 0.8mm diameter brass tube and all mounted on a small piece of plastic strip.
Sticky Wickett
#800 Posted : 22 March 2019 00:12:22
Locking pins fitted.
Guest (10)
This page was generated in 0.485 seconds.
