Joined: 04/06/2010 Posts: 332 Points: 1,000 Location: Bannockburn
Build Stage 12 - The upper exhaust pipe. Parts required: A, B, C and D from Parts 11 Also required: The upper silencer from Stage 11. Brackets A and C are fitted to the exhaust pipe. The exhaust pipe is attached to the silencer and held with bracket D. bugsec attached the following image(s):
Build Stage 13 - The lower silencer. Parts required: A, B, C, D and E from Parts 12 Also required: The two parts of the silencer are fitted together and the brackets added to hold in place. bugsec attached the following image(s):
Build Stage 14 - The lower exhaust pipe. Parts required: A, B and C from Parts 13; F from Parts 14. Also required: The lower silencer from Stage 13. The two exhaust pipe sections are fitted to the silencer and held using the brackets. bugsec attached the following image(s):
Build Stage 15 - The horn. Parts required: A, B, C, D and E from Parts 14. Also required: The cable from the circuit board if fed through the horn case then the circuit board is fitted into the recess in the case. The horn cover is fitted onto the front of the horn case then the mounting plate is fitted to the rear of the horn case. bugsec attached the following image(s):
Nice update and looking good
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,224 Points: 21,979 Location: Northamptonshire, England
Coming on very nicely. Great update. Mark Regards Markwarren (Mark) Admin
Very nice work indeed, making beautiful progress.... Regards Alan
 All looking good from here and nicely done Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks for looking in and the kind comments guys. My New Year Resolution will be to keep up to date with builds and build diaries Graham
Your build is coming along very nicely, good work.
Nicely done Graeme  will be following your build. Al
Thanks all for the kind comments. Pack 04 contains Stages 16 - 21 Parts supplied: Parts 16: A - Number Plate B - Number plate mount and rear light C - Screws Parts 17: A - Left body frame Parts 18: A - Clutch linkage B - Clutch linkage plate C - U-shaped clamp D - Screws and fittings E - Spring F - Linkage road Parts 19: A - Gearshift pedal plate B - Linkage arm C - Linkage D - Gearshift pedal E - Pedal rubber F - Fittings Parts 20: A - Right body frame B - Screws Parts 21: A - Footbrake plate B - Footbrake pedal C - Brake pivot D - Linkage E - Fittings bugsec attached the following image(s):
Build Stage 16 - The number plate Parts required: A, B and C from Parts 16 Also required: The sissy bar from Parts 15. The number plate mount is fixed to the sissy bar using the provided screws. The number plate is then fitted to the number plate mount using the pins on the number plate. bugsec attached the following image(s):
Build Stage 17 - The body frame Parts required: A from Parts 17 and A and B from Parts 20 Also required: The two frames halves are aligned then fixed using the screws provided. File Attachment(s): 047.jpg (268kb) downloaded 63 time(s).
Build Stage 18 - The clutch linkage Parts required: A, B, D (some parts), E and F from Parts 18 Also required: The bolt with the eye is fixed to the clutch linkage using the nuts. The clutch linkage and the clutch linkage plate are fixed togetjer using the washer screw. The linkage rod is secured to the linkage plate with nut and bolt. Finally the spring is connected between the eyebolt and the post on the linkage plate. The remaining parts are stored for later use. bugsec attached the following image(s):
Build Stage 19 - The rear brake Parts required: A, B, C, D, E and F from Parts 19 Also required: The pedal rubber is fitted to the gearshift pedal. The gearshift pedal and linkage arm are then secured to the gearshift pedal plate using a washer screw. The post on the end of the linkage is fitted into the end of the linkage arm and secured with a nut and bolt. The remaining parts are stored for later use. bugsec attached the following image(s):
Build Stage 20 - The footbrake Parts required: A, B, D and E (some parts) from Parts 21 Also required: The bracket is attached to the linkage using the nut and bolt. The linkage is attached to the footbrake pedal using another nut and bolt. The footbrake pedal is attached to the footbrake plate using the bolt supplied. bugsec attached the following image(s):
Build Stage 21 - The brake pivot Parts required: C and E (some parts) from Parts 21 Also required: The pin is inserted into the brake pivot. All unused parts from the pack are stored for later use. bugsec attached the following image(s):
Pack 05 contains Stages 22 - 27 Parts supplied: Parts 22: A - Brake disc B - Sprocket Parts 23: A - Drive chain Parts 24: A - Crankcase B - Tappet guide C - Plug D - Washer screws Parts 25: A - Transmission case B - Screws Parts 26: A - Screws B - Oil filter top C - Oil filter Parts 27: A - Screws B - Transmission cover C - Distributor base D - Gasket E - Distributor bugsec attached the following image(s):
Build Stage 22 - The transmission Parts required: B, C and D from Parts 24, A from Parts 25. Also required: The plug is inserted into the tappet guide then the tappet guide is attached to the transmission case using a screw. bugsec attached the following image(s):
