19 Pages «<23456>»
#61 Posted : 12 February 2019 23:15:27
Looks like a lot of work to get the outside shape, but will be worth the effort.
WTG Cool Cool Cool
#62 Posted : 13 February 2019 20:03:56
Your right there Derek about the work,the main thing with this was to try and keep the same curve all round,and that can only be achieved by sanding down to a knife edge and continuous checking.Thanks for turning the pages.
Trev.
#63 Posted : 13 February 2019 21:10:53
A lovely clean job TrevBigGrin nice work.
#64 Posted : 15 February 2019 08:00:14
Thanks for looking Al, had a problem when assembling the length beams when cutting clefts on the two suspension stabilizers, I slipped and ran off chipping the wood,so I have had to scratch build three more to match.
Trev
kpnuts
#65 Posted : 15 February 2019 14:59:13
Looking great, lot of work going into this
#66 Posted : 16 February 2019 20:50:37
Hi Ken,
Good to see you looking in thank you more soon
Trev
#67 Posted : 26 February 2019 22:02:00
Hi Trev. looking fantastic very nice work. BigGrin Drool
Kev the Modeller
#68 Posted : 28 February 2019 21:20:32
Lovely work Trev, all looking good and really taking that classic stagecoach shape now with your external ribbing, which will look impressive when you've added the outer skins.
Well done mate, nice job. Cool ThumpUp
Per Ardua Ad Astra
#69 Posted : 03 March 2019 19:12:24
Hi Kev,
Thanks for looking in,added skins to the build, glued them as close as possible which will help with the final finish more soon.
Trev
#70 Posted : 03 March 2019 19:40:01
Hi all,
Just a quick update on progress I have finished fitting 1x5mm outer beams and shaping, also removing the sharp edges this will give a bulging effect ready for the dark outer wood more soon.
Thanks for looking
Trev.
Kev the Modeller
#71 Posted : 03 March 2019 21:48:45
A lovely job as always Trev and I love the neatness you are showing in your work, well done. ThumpUp
Per Ardua Ad Astra
#72 Posted : 03 March 2019 22:58:41
Great job Trev BigGrin looks spot on.
kpnuts
#73 Posted : 04 March 2019 07:19:18
Looks great so far.
#74 Posted : 04 March 2019 08:34:56
That’s lovely work Trev.Love
#75 Posted : 04 March 2019 11:45:31
Hi Guy's,
Thank you for looking in.
@ Kev Sometimes I get so involved it becomes hard to keep neat and tidy.
@ Spal Moving on now not only with coach work but also with the suspension.
@ Ken looking forward to building the outer wood which will be a high polish.
@ Mark this build is so well thought out that I have a job to stop building it's so different.
Regards Trev.
#76 Posted : 17 March 2019 22:06:38
update:17.3.19
With the dark wood 1.5 mm I have added back and front following the fitting order as shown in my photo above,then to sand down with a fine grain sand paper until the surface is smooth and uniform.
Then cut pieces from 0.6x30 sheet to line the exterior part of the curved wall, I used a brush to spread the glue over the entire walls, once the glue had dried I cut away all the surplus edges and sanded down leaving entire surface smooth and even,having reached this point I intend to polish the wood.
Trev.
#77 Posted : 17 March 2019 22:33:53
Wow that`s looking real good already.
When you`ve given it the full treatment it will be superb.
Cool Cool Cool Cool Cool
Keep it up.
#78 Posted : 18 March 2019 07:11:06
Hi Derek, have started the polishing but very time consuming and you need a lot of patience.
Trev
#79 Posted : 18 March 2019 08:49:55
That is really looking excellent Trev, great work.
#80 Posted : 18 March 2019 10:05:29
Looking really impressive, all you're hard work is paying off....Drool Drool
19 Pages «<23456>»
