80 Pages «<4041424344>»
Kev the Modeller
#821 Posted : 23 March 2019 14:18:40
Excellent work as always from you Phil, it's a pleasure to follow your build. Cool ThumpUp
Per Ardua Ad Astra
Sticky Wickett
#822 Posted : 25 March 2019 17:52:19
kpnuts wrote:
Incredible work my friend just incredible
Thank you very much Ken!BigGrin
Phil W.
Sticky Wickett
#823 Posted : 25 March 2019 17:52:47
BigGrin All looking good Phil, reminds me of doing the guns on my SchnellbootCool
Thank you very much Andy!BigGrin
Phil W.
Sticky Wickett
#824 Posted : 25 March 2019 17:53:16
This one is in a class of its own Phil, awesome.....Love Love Love Love
Thank you very much Alan!BigGrin
Phil W.
Sticky Wickett
#825 Posted : 25 March 2019 17:54:00
Thank you very much Kev!BigGrin
Phil W.
#826 Posted : 25 March 2019 19:29:59
Building at a different level there Phil. Never seen anything so detailed that is all being scratch built - its look fantastic.
You seem to be well skilled with 3d design and printing as well. Are your prints resin based? They look like they might be.
Hope it all continues well.
Sticky Wickett
#827 Posted : 27 March 2019 15:40:26
Thank you very much Tony!BigGrin I bought the base models from Shapeways - a 3d printing company.
The 3d printed base models aren't great, as all that small detail is very fragile when printed and easily broken. This was the reason i decided to substitute anything that I felt wouldn't stand the test of time with brass, aluminium and acrylic. A time consuming job, but worth it i feel.
Phil W.
#828 Posted : 27 March 2019 21:52:31
Phil
Thanks for the update.
I had come across shapeways recently as i have an old revell Dresden kit and the main guns are a letdown and a couple of online builds suggested shapeways for parts.
Must admit though what you are putting together is sonething very special indeed and its jot just the building but all the knowledge of the thing that impresses me.
Sticky Wickett
#829 Posted : 28 March 2019 23:24:10
This weeks update sees the modifications carried out on the two 2.0cm Flak 38 guns that will be located on the upper deck of the conning tower.
These two guns were bought as 3D printed items, but suffered from being very fragile and so it was necessary to replace the smaller details making them more robust in the process.
I also wanted the guns to pivot on their mounts so that I can have them aimed upwards which meant scratch-building the 'a-frames' that connect the guns to the their mounts.
For these i used 1.0 x 1.5mm plastic strip, with one length bent around a needle file handle to obtain the correct curve. I also drilled through the guns with a 0.5mm diameter drill so I could insert a brass rod, cut to length to act as pivot point. See attached photo.
Sticky Wickett
#830 Posted : 28 March 2019 23:25:07
From another angle with the original parts next to them.
Sticky Wickett
#831 Posted : 28 March 2019 23:26:09
I then made locking levers from brass rod and plastic strip to replace the original parts.
Sticky Wickett
#832 Posted : 28 March 2019 23:27:06
I also scratch built the cocking levers to replace the originals as these were also very fragile.
Sticky Wickett
#833 Posted : 28 March 2019 23:27:36
Both cocking levers fitted.
Sticky Wickett
#834 Posted : 28 March 2019 23:29:23
I then proceeded to fit the after-market gun barrels. I posted a description of these gun barrels in a previous thread.
Sticky Wickett
#835 Posted : 28 March 2019 23:30:22
From another angle, showing both guns fitted with their double barrels.
Sticky Wickett
#836 Posted : 28 March 2019 23:32:59
That concludes this weeks update. Next week I will continue adding details and replacing fragile parts on these guns and their mounts.
Thanks for looking in, have a great weekend and happy modelling!BigGrin
Phil W.
#837 Posted : 29 March 2019 10:33:26
Flak guns look amazing Phil, excellent work as always....Drool Drool
Sticky Wickett
#838 Posted : 29 March 2019 17:07:46
Phil W.
#839 Posted : 30 March 2019 01:23:02
BigGrin All looking good Phil and nice workDrool Drool Cool
#840 Posted : 30 March 2019 09:44:33
Excellent work as usual Phil Love
Guest (10)
This page was generated in 0.804 seconds.
