kpnuts wrote:Incredible work my friend just incredible Thank you very much Ken! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
arpurchase wrote: All looking good Phil, reminds me of doing the guns on my Schnellboot Thank you very much Andy! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Gandale wrote:This one is in a class of its own Phil, awesome..... Regards Alan Thank you very much Alan! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Kev the Modeller wrote:Excellent work as always from you Phil, it's a pleasure to follow your build.
Kev  Thank you very much Kev! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Building at a different level there Phil. Never seen anything so detailed that is all being scratch built - its look fantastic. You seem to be well skilled with 3d design and printing as well. Are your prints resin based? They look like they might be. Hope it all continues well. Happy Modelling
birdaj2 wrote:Building at a different level there Phil. Never seen anything so detailed that is all being scratch built - its look fantastic.
Hope it all continues well. Thank you very much Tony!  I bought the base models from Shapeways - a 3d printing company. The 3d printed base models aren't great, as all that small detail is very fragile when printed and easily broken. This was the reason i decided to substitute anything that I felt wouldn't stand the test of time with brass, aluminium and acrylic. A time consuming job, but worth it i feel. Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Phil Thanks for the update. I had come across shapeways recently as i have an old revell Dresden kit and the main guns are a letdown and a couple of online builds suggested shapeways for parts. Must admit though what you are putting together is sonething very special indeed and its jot just the building but all the knowledge of the thing that impresses me. Hope it all continues well. Happy Modelling
Good evening from 'The Dockyard'. This weeks update sees the modifications carried out on the two 2.0cm Flak 38 guns that will be located on the upper deck of the conning tower. These two guns were bought as 3D printed items, but suffered from being very fragile and so it was necessary to replace the smaller details making them more robust in the process. I also wanted the guns to pivot on their mounts so that I can have them aimed upwards which meant scratch-building the 'a-frames' that connect the guns to the their mounts. For these i used 1.0 x 1.5mm plastic strip, with one length bent around a needle file handle to obtain the correct curve. I also drilled through the guns with a 0.5mm diameter drill so I could insert a brass rod, cut to length to act as pivot point. See attached photo. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
From another angle with the original parts next to them. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I then made locking levers from brass rod and plastic strip to replace the original parts. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I also scratch built the cocking levers to replace the originals as these were also very fragile. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Both cocking levers fitted. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
I then proceeded to fit the after-market gun barrels. I posted a description of these gun barrels in a previous thread. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
From another angle, showing both guns fitted with their double barrels. Sticky Wickett attached the following image(s): Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
That concludes this weeks update. Next week I will continue adding details and replacing fragile parts on these guns and their mounts. Thanks for looking in, have a great weekend and happy modelling!  Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Flak guns look amazing Phil, excellent work as always.... Regards Alan
Gandale wrote:Flak guns look amazing Phil, excellent work as always.... Regards Alan Thank you very much Alan! Regards, Phil W. Completed projects: 1/43 scale Bedford HA van / 1/43 scale MG TD sports car Current projects: 1/48 scale U-boat [U230] Future projects: 1/148 scale railway diorama / 1/50 scale R/C Volvo F89 logging truck / 1/148 scale Thunderbirds Fireflash
Excellent work as usual Phil Mark Regards Markwarren (Mark) Admin
Guest (16)
